asp.61 carb problems
OH
ok here is what is going on i have a air leak aroing the barrel of my asp.61 carb i found this out by placing my finger over the carb and it still ran i suspect thats its where the barrel and the carb gasket comes togher anyway to fix this?
OH
RE: asp.61 carb problems
i allrealy replaced the one where the carb and the motor meet seems the air might be leaking arounf the throttle lever side of the carb where is a rubber boot thats around the carb anyway to fix that?
OH
ok figured it out 1 my highspeed needle was leaking replaced the oring 2 the rubber gasket around the inner berral was leaking fix that with a o ring behind it last the screw that put tenshion on the berral was leaking so added a o ring behind it aka all air has stoped will test it soon and will post resalts
