TWist 40 covering
Reply
Old 09-11-2010, 07:11 PM
andrewskj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default TWist 40 covering
I have a twist 40 just finished and need to tighten up the covering . Is this coverite and if so what heat setting should I use ? On open sections do I use heat gun or iron with cover on it? Please help if possible and thank you for your consideration.
Ken
andrewskj is offline
Old 09-11-2010, 07:44 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: TWist 40 covering
It is Ultracote or the same as Oracover
You can use a gun but sometimes I use the iron
w8ye is offline
Old 09-11-2010, 08:53 PM
mikegordon10
mikegordon10's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you use the heat gun be careful around the edges. I use a piece of card stock to shield the edges so they don't loosen with the heat. Other than that it shrinks up nice and tight, If you need to shrink it up around the edges use either a trim iron (my favorite) or a covering iron with a sock on it.
mikegordon10 is offline
