Removing dry epoxy from Ultrakote?
Has anyone done this with excellent results? plz, i would really appreciate any help on how to remove dried epoxy from ultakote... steve :)
take a paper towel wet with methanol and let it set over the epoxy for a while. rewet and start rubbing lightly. works for me most of the time.
Ed M. |
methanol... where can i get that?
Acetone will do it.
Use your heat gun for a few miuntes. It will break down the glue and then wipe it off with alcohol or acetone.
Shortman,
Try the hardware store methanol = wood grain alcohol isopropanol = rubbing alcohol (drugstore) will work, but not as good in my opinion. Ed M. |
okay, thanks guys
