It just wont start!
It just wont start!
Got a fairly old 1/8th buggy running a .27 team infinity engine. recently tried to get it running. its had new:
Pull start
fuel tank
fuel lines
glow plug
priming pump/filter
radio gear
battery for glow heater
fuel 16%
can feel the heater heating the glow plug, just does not fire.
Any ideas?
Pull start
fuel tank
fuel lines
glow plug
priming pump/filter
radio gear
fuel 16%
Any ideas?
As above ensure fuel is getting through....are you priming the fuel properly (have to ask).......does the glow plug get wet after trying to start or does the engine flood with fuel......have you checked/adjusted the carb. settings?
16% nitro content is low for that size of engine really...but it should still fire....what fuel and plug are you using?
IL
Air, fuel, spark.
You report air and spark, so, missing fuel.
Remove the glow plug and drip in 10 drops of fuel. Replace glow plug and try again. If it runs on the prime then stops it is not receiving fuel. Check the needle setting, carb fuel path from hose barb to fuel outlet pipe (clean and blow out).
Then try again.
Then try again.
