Official Hyper 8 Thread
#1401
GA
RE: Official Hyper 8 Thread
I do not know how many tracks in the UK but over seas RC is more popular or it seems that way. I hope one day you get to race and if you are like I you will never be happy with bashing again. What is the closes track to you and how far away is it?
#1402
TX
I was a bashers for years, then went once to the track, and never came back to the bashing area lol, it just gets boring after a while, and when you race, you never get bored!
#1403
It's Bowetrix?? think how you spell it in Clanfield, it not too far but my friend went there before years ago and raced few times, I agree I race my mate's tamiya car and my Assosiated RC18B 1:18TH Scale on a homemade track,And love it. I once sorted the elecs out am going down there. And will probally never bash again!!! Hopefully,Bashing turns out bordeness then stupid size jumps =Damage
#1404
TX
Hey guys, I received the Orange Springs for the H8.5 Big Bores from Taiwan today. I had to take a small preload I had in the front shocks and put it in the rear, I like how the suspension feels with these springs and I also like how the ground clearence ended up. I'll test them tomorrow at the races. Here are some pics:
I'm running a Werks TLB3 21 engine right now but in the next couple of weeks i'll be running a Ninja [>:]
#1405
NC
Hey, guys havn't been around to converse latly. (been looking into the CRT .5 too much)
Looking around on eBay and all of a sudden there are alot of Hyper 8/8.5s for sale so I might just have to pick me up one.
zJatoRad have you tested the Advantage wheels yet?
Also if I get a normal Hyper 8 not the pro version am I really missing out on anything? I am sure I would upgrade as time goes on but I might be able to get one locally that has most of the upgrades but started out as RTR.
#1406
TX
Hey ProcessRacing, sorry but have not tested the advantag wheels yet, they are just sitting on my tire tote, waiting on the Losi XBT tires but they are back ordered.
coinsidently, I also been looking at the CRT .5, gonna get one myself in a couple of weeeks =D
#1407
GA
Will not be long before my new 8.5 will be ready to break in with my new STS D21T MKII and our new track with a centerline of 1,100 feet is all so just about ready.
#1409
NC
They are designed so much better then most of the other mini nitros, they are a little bigger but they are in the same layout as normal 1/8 scales and have 1/8 clutchs and used small blocks and now with standard servos. But I also realized I could almost get a good Hyper 8/8.5 setup for how much I would spend on a CRT .5.
#1410
GA
The CRT .5 are cute but there is NO way I would take it over my Hyper 8 or 8.5 Pro!!! They started a class for them here in Georgia at a few tracks but they just do not handle the tracks as well as the 1/8 buggies do.
#1411
NC
Well I finally bidded on one today.....
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=018
What do you thing of the deal I got good or bad? I know about his feedback I am getting his phone number before I pay and looked into his details, it all checks out. (I hope)
#1412
AL
ProcessRacing ~ I have tested the advantage racing wheels and am very pleased with them. The are much lighter than the ofna spoked wheels I have been using for the past six years and are very tough. I've been using them for about three weeks now. I've had a few awkward landings on them and even smacked a plywood wall at the end of a back straight when I missed my braking point a couple of times. These wheels are as strong as Advantage racing products claims.
#1414
TX
well the Ninja was out of stock so I went ahead and bought the RB WS7 III w/ a Jammin Products JP-4 pipe, can't wait for races this sunday!
#1417
hi there i just got myself a 8.5 pro to start racing , i feel like the stock foam is a bit big for the tire ?
do you just put it like that or cut something ?
and also i was told no pull start for this kit unless i change the engine mount right ?
#1418
GA
Good chance with the stock mounts you will not be able to run a pull starter, as the pull starter will hit the chassis. If you are going to race you would be much better off using a starter box! I have a Hyper 8 and I am building a 8.5 out of pieces but do not have the stock 8.5 tires and foams so I cannot say much about this issue but I can say some foams do need to be trimmed with some tires.
#1419
TX
stock tires wear out extremely fast even on dirt but they did hook up great, I didn't had to trim the foam, I just fitted it in there
#1420
good i glued the stock tire as good as i could not perferct ...;
i bought a set of proline ready to go bow tire
and good news i got my italian engine , novarossi P5X !
anyone got this engine too ? it look good and i heard it perform well .
#1422
is the clutch assembly for the 8.5 the same for the 8?
on the manual iam a bit lost with all the different shim/washer , also the clutch nut is not the same that on the drawing , its a bit rounder on one side , i guess this side goes to the clutch as the flat side retain the fly wheel ?
thx for any infos on the assembly for 8.5 !
ps : my engine rub a little the chassis on the test fit , there is a resess for the engine to sit , but still i need to sit it a bit higher ,0.5mm, where should i put spacer or shim , between engine mount and engine or engine mount /chassis ?
if i do it to only one side of the engine is it ok , it will titl a little on the center of the car .
#1423
GA
The 8.5 has a lighten flywheel and alloy shoes but both the 8 and 8.5 mount similar. The shims are for spacing the flywheel and to set the end play on the CB. Yes the rounded part on the flywheel nut goes towards the CB or that is how I have all ways run it on my 8 for well over 9 gallons. Will not be much longer and my 8.5 will be running.
#1424
ok thank you very much , the shimming is between the nut and the first bearing of the CB right ?
i have mounted it with 0.2mm of end play , with the smallest washer , i can have any more play ,sound good ?
What about the engine not sitting flush on the car should i add a tabb of something between engine and mount ?
