Stearing servo moving by throtle triger
Hello my name is je park. in korea.
I using 4pk 2.4G
Pulling the throttle lever steering servo moves!
Setting information can be seen in the picture
and movie is follow the link.
https://youtu.be/UpRUAw0YL0Y
https://youtu.be/ig8Uq_bls6w
I think the problem seems transmitter
because I had chaned reciever,servo,chaged the model. but same symptom.
Please tell me the solution.
I using 4pk 2.4G
I would be surprised if the steering servo worked at all with the linkage shown - the two link rods should be parallel to avoid lock-ups and putting too much strain on the servo.
A boat like that should need only the most basic setup. One channel for throttle, another for steering, and thats it, no mixing. I an not familiar with that transmitter, so I don't know if it comes with some mixing already programmed in.
Of course, the ESC and steering servo need to be plugged into their correct channels on the receiver.
A servo can only respond to the signal that it gets from the receiver. The signal is compared with the line voltage that the servo gets, so any fluctuations in the line voltage will cause the servo to twitch. From the video I can;t tell whether it is twitching or trying to move fully and being jammed by the bad steering linkage geometry.
If the system has the ESC unplugged and powered by a separate RX battery, check if the servo then responds to the throttle channel as well as the steering channel. If it does, either the transmitter is applying mixing or faulty, or the receiver is mixing the signals, which should not happen with one working correctly. This is why I prefer simple transmitters rather than programmable types. Less to go wrong, and two separate sticks reduces the chance of my fingers working the wrong control.
First thing I would do is take the rudder pushrods off the servo arms. As said above, the rudder linkage needs to be straightened out as the way it is now, it can't move. After you have the rods removed, try the radio and see what it does. If it works properly, you found your problem. IF it doesn't work properly, I would swap out the servo with a new one. The new servo does not have to be installed for testing, since this is just verification. If the new servo doesn't work properly, change the receiver
