RC Boats General Discussion Discuss general rc boating topics here.
RC Surfer
Old 03-10-2014, 03:16 AM
  #7551
Darkseacret
Do most people use stock water inlets on a NQD or should I drill out and epoxy some brass tubing inlets/outlets instead? Now that Im getting serious on this build I get all OCD about it loosing sleep thinking about stupid things like brass tubing and foot straps lol.
Old 03-10-2014, 05:26 AM
  #7552
bearcave
Darkest of secrets about nqd fixin up is within the many pages of this site... it may take several weeks to view it all as you have to read all the pages.
Oz site '******************' and kite's site 'rc surf world' have some of the relevent stuff easier to find but will still be time consuming.
Most of the custom guys (or totally addicted like you are now lol) all started with an nqd/kyo/boardsharks and comments like hugh made about stickin the lead down good (roughing up the abs plastic befor glueing gives a much better bond too, and keep ya ballast low) are true cause they have been there.
Anyway.... have only seen a few picks of a split open nqd, cool. On my one just sealed the join externally and it selfrights ok with whatever stock weight ballast is in there. I found it goes way better with more ballast futhar fwd, would suggest getting all your stuff together within the board for a 'how it will be' mock up and aim for a balance point half way along the length (stock balance is furthar back) to work out where to glue your custom lead.
Cooling wise most of the custom guys are running one inlet into esc then motor then out... from what i see all is good.
My aproach was dual inlet and suction outlet. On one hand best case scenario cooling wether its neccesary or not. On another hand if a blockage occurs i may only overheat the esc OR motor, not both.
End of day thinkin if no blockage occurs all should be good...
I've used a mini thermometer on many things to check temps (was way helpful tuning/ keeping a nitro burning engine happening) but as a basic thing i've noticed on anything electrical, after a run and the motor or esc is too hot to touch you have unmatched motor/esc/prop load electrical issues or cooling problems.
not knowin much just sayin deffinately change the plastic pickup/exhaust out to glued in brass tube, going for a smooth as can be flow in and out.
hopefully others will suggest other things as well but if not check out the other sites for more info..
Old 03-10-2014, 11:59 PM
  #7553
YPC
YPC's Avatar
Howzit Darkseacret !......most guys will say 'two is better than one".......only joking..
Some say that when surfing in the warmer waters two intakes are better for overall cooling...I have found in SA - water temps average around 15 degrees i the single inlet / outlet has worked well (4 mm OD brass tubes)
Remember to always lead the cooling pipe to the ESC first - then to the motor - the esc needs more cooling than the motor..
below is a link to a previous post I posted when installing th etubes in one of my recent boards..
http://www.rcuniverse.com/forum/rc-b...l#post11740263
Old 03-11-2014, 01:31 AM
  #7554
YPC
YPC's Avatar
Default Boards balance and dead weight
In the build I establish the boards CG at 40% of the length of the board from the tail..in a ready to surf state...that is whenI I then add any further required dead weight - (after the final build is complete), to establish the ideal running weight -found that 2400 grams (5.3lbs) Ready to Surf for my boards using 3s-4s - seems to work well for its bouyancy factor and in most all surf conditions.
I use lead shot gun pellets, bedded in epoxy - usually between 100 - 150 grams - moulds well into spaces - best to be placed at the lowest possible CG.
Old 03-11-2014, 01:39 AM
  #7555
bearcave
while your nqd is split one more thought from the cave.
screw stainless steel bolts up the 4 stock nuts that hold the deck down.
I hear the kyo hollow hulls have stainless nuts? but nqd's have rusty steel nuts.
many have done the staino bolt thing (like glue them into the rusty nut) and then use some kind of wingnut holdown for the deck instead of the std screws.
Of course if you can get them rusty nuts out and replace with stainless ones even better but thinkin they may be hard to dislodge without breaking plastic....?
I wanted to do this but hessitant to drill through the bottom of hull just keep sticking grease down the nut cavitys.. but if i ever split one i would be thinkin about it.
while your at it might as well drill out the rudder hole and stick something brass or stainless in there too.
enjoy your addiction darkseacret....
Last edited by bearcave; 03-11-2014 at 03:42 AM. Reason: added the rudder hole beef up...
Old 03-11-2014, 09:37 AM
  #7556
Darkseacret
Thanks Bear . Awesome tip with ss bolts up through base. Thank you .
Old 03-12-2014, 07:46 PM
  #7557
ronkytonk
What's up boy's'
I have a box o Hobbyking parts and a BoardShark looking for some lovin, I finally started at it since the snow is melting in my neck of the woods.
I stripped the Shark down to nothing and started with the coooooling system.
I found some sand from the westside of Oahu and filled a brass tube with it and started bending..
After an hour with a Dremel on the tubing and hull I started putting some parts into place (I will epoxy when I am done fitting all the parts).
I hooked up the esc, receiver, and motor to get everything working...
Have a listen and tell me if it sounds ok, reminding nothing is epoxied yet.
https://www.youtube.com/watch?v=W1c8f5ZV3XA
I am now onto figuring out the most important thing (to me), hooking the dudeshark to a low pro servo!!.
DUDE NEEDS TO HAVE MOVEMENT!!
ID:	1977606   Click image for larger version
ID:	1977607   Click image for larger version
ID:	1977610   Click image for larger version
ID:	1977611   Click image for larger version
ID:	1977612   Click image for larger version
Old 03-12-2014, 11:37 PM
  #7558
bearcave
Hey ronkytonk looks/sounds like a strait driveline from here.
I couldn't find any hawaiin sand so used generic worldwide salt to pack my tubes.. lol couldn't help myself on that one... anyway i went for the low rider reduced obtrusion minimul drag inlet/outlets.. they seem to work ok, here is a pic
Regarding the leaning guy, reckon a pm to K-H2o way to go.
Darkseacrets... beefing up the engine mounting screw point while you have a split nqd might be a good idea too.
Bad Billy made some awesome engine mounts a while back too... not sure if you can still get em but worth a look.
Name:	bstail cooling.JPG
Old 03-13-2014, 12:56 PM
  #7559
YPC
YPC's Avatar
Been surfing On-Shore conditions the entire week - really enjoy finding those little pockets and moments in the midst of all the lumps and bumps' My daughter Jessie got behind the camera - filming On-Shore Beach Break is difficult - all over the show - the young lady did well !
http://www.youtube.com/watch?v=0f-DBhBDdtw
Old 03-13-2014, 11:37 PM
  #7560
YPC
YPC's Avatar
Here is a great article to read - relating to modern day surfing - and the evolution of surfing ...
Article link:
http://mauinow.com/2012/10/18/power-sur ... n-surfing/
http://www.youtube.com/watch?feature=player_embedded&v=ROVHVQ6yrWU
Old 03-15-2014, 01:50 AM
  #7561
YPC
YPC's Avatar
Further Bi-Fin Development - adding more features !
http://www.rcuniverse.com/forum/rc-b...l#post11760121
Old 03-16-2014, 05:39 PM
  #7562
Darkseacret
Ordered the FS Gt 2 2.4 radio.
http://www.ebay.com/itm/FS-GT2-2CH-2...ht_2762wt_1096
Old 03-17-2014, 08:34 AM
  #7563
YPC
YPC's Avatar
A video to demonstrate the various Bi-Fin Toe' dynamic effects....having the ability to simply/effectively change the boards angle of attack and ride attitude, makes for an even finer tuned set-up - which makes for better surfing overall !
http://youtu.be/ZJeyAwYcCi4
Old 03-18-2014, 04:52 AM
  #7564
ronkytonk
Default Need advise on movement
Hey Guy's,
Any Ideas on how I could get a better range of movement with the servo?,
I know it's taped, I just don't want to make anything permanent.
Thx
https://www.youtube.com/watch?v=0GBT_j4TQ0M
Old 03-18-2014, 05:56 AM
  #7565
YPC
YPC's Avatar
Ronky !...just shorten the length of the leverage ( the long lever that seems to be attached to the surfers movement components)
Old 03-18-2014, 12:00 PM
  #7566
YPC
YPC's Avatar
Quick ! late afternoon session !........not bad for a Tuesday !...enjoy working the little spots on the wave to pull the odd nice move...when it happens it's rewarding..
https://www.youtube.com/watch?v=lmoc93oIzBs
Old 03-19-2014, 02:50 AM
  #7567
bearcave
Ronkytonk. levers and angles wise bro says true.
For example, if you reversed your servos direction, had your actuating rod mounted to the opposite side of the servo horn, then ran straight back to the guys actuating arm and attaching half way along, you would double the guys movement.
Down side is that twice the tourqe (and power) would be required to move him and handle the load.
Seeing your setup i'm now thinkin the arm has to be short for sufficient movement, and maybe why the servo's for the guy have to be mega tourqe mega strong compared to steering servo's.... ?
Cool setup ronkytonk never thought of doing it that way with servo up front, one day i hope to get my one happening way interested in your quest!
Old 03-19-2014, 06:18 AM
  #7568
ronkytonk
Alright here is a pic of the bottom of the Dude lever..
I just drilled a hole lower down on the lever and hooked it up. I can tell the servo is working a little harder but Dude has more movement. I believe if I fool around a bit more I could get it even more movement, also once I drop the servo into the boardshark lid permanently it won't move as much because it is just tapped into place now.
Here is a vid of it after the slight adjustment..
https://www.youtube.com/watch?v=oFd37DOh8-Q I almost think I may have enough sauce on the dude movement for now, and now I may move onto the rudder/servo..
As you can see I still have a little snow on the ground, so I still have some time until the lake is ready to be surfed!!lol
ID:	1979487   Click image for larger version
ID:	1979491   Click image for larger version
Old 03-19-2014, 01:03 PM
  #7569
YPC
YPC's Avatar
Default first Winter swell
Got a taste of Winter to-day - looking very promising !
https://www.youtube.com/watch?v=9KgY3GRxIpw Looks like I am in for a nice weekend !
(Wednesday 19 March 2014)
WEDNESDAY hubba! A gnarly taste of winter this way comes as 20 SECOND swells pulse to 25 feet (or bigger) on deep-water reefs. Day starts cloudy rainy light NW and already 6'. All day, the grunt grows and grows and grows. Make the circle bigger! Muizies fills with cooking 4'+ lines, 3' at first. Winds moderate NW going SW to W.THURSDAY still 20ft throbbing in light SE going S. Muizies 3-5' and fun at dawn. FRIDAY 4-6' leftovers drop all day to 3-4' in clean SE. Muizies bumpy dropping 2-3'. What a run! SATURDAY hey hey hey, another bit of winter with moderate NW going fresh and 3-4' seas. Muizies offshore 2' fun. SUNDAY lekker Muizies day, with 2-3' lines in light NW offshore. Other side could be fun too, with bit more juice and 4' sets or more open coast. Light winds.
[TABLE="class: framedLeft, width: 300"]
[TR]
[TD][/TD]
[TD="align: center"][/TD]
[TD="width: 60, align: center"][/TD]
[/TR]
[TR]
[TD="width: 60, align: center"]Wed[/TD]
[TD="width: 60, align: center"]Thu[/TD]
[TD="width: 60, align: center"]Fri[/TD]
[TD="width: 60, align: center"]Sat[/TD]
[TD="width: 60, align: center"]Su
[/TD]
[/TR]
[/TABLE]
Old 03-20-2014, 04:47 AM
  #7570
bearcave
hey bro i can't see any of your vids... says there disabled by request and i must watch on youtube
ronkytonk.. winter lookin good in your world, snowbored snowboard hey
Old 03-20-2014, 05:06 AM
  #7571
YPC
YPC's Avatar
BC - thanks for the 'heads up'......for some reason the 'allow embedding box'was not clicked so it could have been that ....please let me know if it is sorted
Thanks Mate !
looks like I'll be having a good few sessions for the rest of this week !!!!
Old 03-20-2014, 03:11 PM
  #7572
YPC
YPC's Avatar
Had an Epic Session this afternoon - A great precursor to my Birthday Friday !...
https://www.youtube.com/watch?v=YPSGCevxeRY
Old 03-22-2014, 05:33 AM
  #7573
YPC
YPC's Avatar
Saturday Morning Session early'.... been having my fare share of surf this week .....enjoying.the first signs of the winter swell trickling into the bay. for the most of it's size - it has been far out to enjoy - even on the high tide - but great intermediate waves to be had.
Demonstrated the neutral and toe - out Bi Fin's difference in this video - makes a positive difference in the windy bumpy conditions...keeping the board on the water'...
https://www.youtube.com/watch?v=3SnPzv7FD8I
Old 03-23-2014, 07:38 AM
  #7574
YPC
YPC's Avatar
Ended the weeks surfing off with a great session down at Cemetery - 3-4ft face - clean pealing waves - had good opportunity to demonstrate the various Toe Fin Dynamics...........whilst enjoying a few good rides....
https://www.youtube.com/watch?v=9BRzXDoerHM
Old 03-25-2014, 01:19 AM
  #7575
YPC
YPC's Avatar
Moments in time .......
ID:	1981232   Click image for larger version
ID:	1981233   Click image for larger version
ID:	1981234   Click image for larger version
ID:	1981235   Click image for larger version
ID:	1981236   Click image for larger version
ID:	1981237   Click image for larger version
