RC Boats General Discussion Discuss general rc boating topics here.
first buld
Old 06-11-2007, 05:04 PM
--shawn--
Default first buld
hey every one my name is shawn and im 16
this summer i plan on bulding a rc boat powered by a weedeater engin,balsa wood and epoxy with some help from my dad we dont really have any experisnce other than this cheep electric one i had when i was 12 but i broke it when i threw it off the dock at m cottage, so i want to keep it really simple but i still want this thing to go
any ways i just have a couple basic questions
1 what type of things will i need to put this to gether servos ex:
2 i dont really understand how the prop shaft goes through the boat without water geting through
3 how much will this cost jsu so i have a good idea
4 how big should this thing be
im looking to have it be something like this http://www.rcgroups.com/forums/attac...hmentid=851739
Old 06-11-2007, 06:04 PM
Hydro Junkie
Hydro Junkie's Avatar
Default RE: first buld
You might want to look at a "Wild Thing". That way you can scale it up or down as you see fit. Stay away from balsa. It's like a sponge in that it soaks up water if the finish is ever damaged. Stick with aircraft grade plywood(not lite ply either) as it's considerably more water resistant and stronger. The other advantage of using aircraft ply is that it's flexible up to 1/16th inch thick.
Old 06-11-2007, 08:18 PM
--shawn--
where do i buy this wood?how much dose it cost roughly?
Old 06-11-2007, 09:19 PM
--shawn--
witch of these packages should i be getting keeping in mind i want this to be cheap
http://www2.towerhobbies.com/cgi-bin...I=LE7104**&P=1
http://www2.towerhobbies.com/cgi-bin...I=LE7157**&P=1
Old 06-11-2007, 11:23 PM
Ron Olson
Ron Olson's Avatar
First, you don't want to use balsa for a gas powered boat.
If you want to build one cheaply, check out www.zippkits.com as he has some fast building inexpensive boat kits for weedy engines.
Old 06-12-2007, 12:16 AM
Hydro Junkie
ORIGINAL: --shawn--
Check out Balsa USA, Lone Star, Tower Hobbies, Sig and I'm sure there are others I forgot.
Old 06-12-2007, 09:58 AM
jdoug
Shawn - Neither one of those radios will work. The radio for a gas boat needs to be FM or you will get interference. AM is too susceptable to "noise" generated by the ignition and spark plug.
I just bought wood from Lone Star Balsa for 2 45 in. woody boats and the total was $100. Not bad at all for Aircraft grade ply.
Old 06-12-2007, 06:30 PM
--shawn--
is there anywhere online where i can get a radio cheep?
Old 06-12-2007, 07:05 PM
Hydro Junkie
You might look at this one
http://www2.towerhobbies.com/cgi-bin...=SM&I=LXEFJ4**
or maybe this one
http://www2.towerhobbies.com/cgi-bin...=LXNHS2**&P=SM
or last but not least this one
http://www2.towerhobbies.com/cgi-bin...=LXGAG4**&P=SM
Old 06-12-2007, 10:11 PM
--shawn--
i think i will end up geting the second one i only need 2ch right? throttle and rudder ,just waiting for school to be out 4 days not counting weekends and exam days [sm=teeth_smile.gif]
Old 06-13-2007, 02:01 PM
--shawn--
would a 20cc be powerful enough
http://www.shopxscargo.com/product_c...ductDetailMore
Old 06-13-2007, 10:07 PM
Flabum
Go around to your local lawn mower shops and see if they have any old weedeaters with a 25cc or 30cc Homelite motor. generally, if they have them, the boom is shot or some other stupid thing that made it too expensive to fix. You just want the motor, you should be able to find one for $10 or less. Remember to ask for a Homelite motor, those can be marinized easily and modded in the future when you learn more.
Old 06-16-2007, 05:41 PM
--shawn--
k i got a 21cc featherlite for $5at a yard sale im just going to need a new fule filter,gas cap and fule lines , what should me next step be?
anyone got pics of the inside of there boats(engine,drive,tank,servos ex)
Old 06-23-2007, 09:33 PM
--shawn--
thats it i am officaly done with this project my engien is giving me a hard time and im already runing out of money [:@]
Old 06-25-2007, 10:45 PM
--shawn--
ok one more try i got the engine working im just trying to make it lighter
just a couple questions
1 where do you get those black rubber things to mount your engine?
2 where can i get my plans printer full size? will somewhere like kinkos do it
3 do my servos have to be in the water proof container or will they get distroyed if they get wet?
4 what type wood should i be bulding my hull of im going to be bulding the wildthing mono?
Old 06-26-2007, 11:47 AM
alloutcustom
aircraft grade ply. you use the flex cable that comes with the weedwacker. you run it through k&s brass tubing to a ferule. then that connects to a 1/4in shaft. you can make struts but i prefer buying them because they are adjustable. rudders are fairly easy to make. you will need brass, solder, and a soldering iron, and flux. try and make it adjustable too, easyier to setup that way. you can run a 70mm prop to start out with and prop up or down from there. you will also want a failsafe if your radio doesnt come with one built in. someone correct me if i am wrong for i have not built one just done research on the subject. ive built many electric boats tho
Old 06-27-2007, 10:14 PM
hse32
you do not have to have FM radio all you need is a resister spark plug
Old 06-28-2007, 10:21 PM
--shawn--
im geting the plans printed tomorrow
my engine spins counter clockwise is this a problem?
