When would I be ready for a kit?
Seriously, Im on my second RTR car and have replaced several parts in each. I look at the kit manuals and they seem pretty daunting. How involved is the assembling? It is showing every washer and part for shocks and everything to assemble painstakingly. I"m not sure I could handle it yet.
RE: When would I be ready for a kit?
Try a simple cheap tamiya kit if you want to see how it is.
They are not hard IMO. I don't think I've spent more than 3 hours on a kit tops. Hardest part depending on the kit I find is usually the shocks (royal PITA on the jammin .5 CRT). I say depending cause some kits the shocks are garbage that I don't bother touching, and put aftermarkets on straight out of the box.
I actually find the kits easier than the models I used to build when I was a kid.
If you ever repaired your RC you can build a kit
TN
Agree shocks are the hardest part, and with take your time and stay organised. Make sure you read the directions thoroughly and it will be fun and easy.
Meafordguy, just strip one of your RTR's totally down and rebuild it. That'll give you an idea of whether or not you find it to difficult.
I just got 2 of the Jammin CRT.5 kits. I too was a little overwhelmed at first, lots of parts. But it was not that bad, if the CRT shocks are the most frustrating then you should have no issues. I am a desk jockey and i put the CRT .5 together with no issues. I had more problemsfiguring out the the clutch assembly, mainly due to my lack of mechanical knowledge. I am a desk jockey and i put the CRT .5 together with no issues.
IL
My first hobby grade car was a kit. Just take your time and you'll do fine. I recommend Tamiya's kits because of their excellent instructions. They even have actual size parts pictures so you can hold the piece up to the picture and make sure you got the right piece.
ORIGINAL: ts99ad
BTW see the .5 kits are now $75 from ofna just got a 2nd the other week
OH
Back when i started rc, there was no such thing as rtr. Everything was a kit. Its not hard AT ALL to build an RC, actually its quite fun. Just make sure to stay organized during the build. Keep small parts in bowls or something. Keep your work area clean, read through the manual before you begin, don't get in a rush. And because your building it, future repairs will be much easier.
ORIGINAL: lez1troubles
THIS!
Thanks for all the replies. That's why I like this forum the best! Well I have done quite a bit of work on my cars already, replaced motor several times on the old brushed volcano, replaced a servo, replaced ball joints, wheels on rims etc. Made numerous repairs, but it's not quite the same as trying to put together a steering assembly for the first time or similar issues. If the instructions were good then yes I could do it, the instruction manuals I've seen so far are nothing more than a schematic, and if that is all I have to go on I'm in trouble.
Maybe one day this winter I'll give it a shot.
