nitro
nitro
hi, i was thinking about getting a new rc car i have been running electric cars but now i want to run nitro cars. is there any suggestions to a cheap reliable easy to run first nitro car that i can purchase thanks
Moderator
RE: nitro
OFNA is a good choice and so is HPI, something like a nitro Firestorm. I normally run 20% nitro in most of my engines, I like O'Donnell fuel myself but others are good too.
As far as starting goes, most engines use a pullstart though I personally like rotostarts. Rotostart systems replace the pullstart with a backplate that has a port for the rotostart wand, which is basically a geared electric motor/battery combination that turns the engine over. It's a lot easier to start that way than with a pullstart. Some cars even have built in starter motors that either use the RX battery or an external one.
RE: nitro
so if i get a pull start car all i need to do is pull the sting and it will start, and can you teach me about breacking the car in too.
thanks heaps
thanks heaps
Moderator
RE: nitro
ORIGINAL: dan rox 90
thanks heaps
thanks heaps
Glow plug ignitor-http://www.amainhobbies.com/product_...tor-AA-Battery
My Feedback: (9)
GA
RE: nitro
That's the high speed and the low speed needle, there is sometimes a mid speed but not very often. Ofna is good choice and the hyper 7 would be good too http://www3.towerhobbies.com/cgi-bin...?&I=LXCWHA&P=M HPI gas been of its game lately, the firestorm is a decent truck but I would choose the ofna or hyper over it anyday.
RE: nitro
[youtube]http://www.youtube.com/watch?v=tNxuZvHRysA[/youtube]
http://www3.towerhobbies.com/cgi-bin...&I=LXBCVP&P=ML good beginner engine in this one, it comes with everything (except fuel) needed to start it, and unlike the hyper 7 its in stock
Moderator
RE: nitro
Ok, i'm going to explain it. This should tell you how to tune;http://www.xenonproject.com/tuning-y...gine-a-10.html
BREAK-IN. STAGE 1.
1. Put a full tank of gas in the rc car. Let it start and idle while you tune the rc car. When you are done tuning, let it idle until it runs out of fuel.
STAGE 2.
2. Put a full tank of gas in the rc car. Let it start, and pick up the back end. Do short inclement bursts of about 1/4th throttle until it runs dry.
STAGE 3.
3. Time for some fun. Put a full tank of gas in the RC car. Let it start, and start doing a figure 8 on your driveway or where you are breaking the rc car in. Do 1/4 throttle while doing the figure 8s. Repeat this step for stage four, and your engine will be broken in.
RE: nitro
ORIGINAL: collector1231
Ok, i'm going to explain it. This should tell you how to tune; http://www.xenonproject.com/tuning-y...gine-a-10.html
BREAK-IN. STAGE 1.
STAGE 2.
STAGE 3.
every engine (outside the K4.6) I've broke in you basically put the RC on a box for steps 1, and 2 and let a full tank just run out
steps 3, and 4 you do 25% throttle while driving in circles on paved ground
5, and 6 is half throttle to 3/4th while doing circles on paved ground with occasional blipping to full
and not to touch the needles till after done with step 6 as the default settings are meant for breakin
also between steps let the engine cool to ambient temperature with the piston stored at BDC(Bottom Dead Center) which is where the piston is at its lowest point in the sleeve
To find BDC before you run the RC take the glow plug out and look down the hole and rotate the flywheel till the piston is at the very bottom, and put a mark on the flywheel wither on the bottom or top(whichever you prefer) so you remember where the bottom is, and rotate the flywheel to that point when done running.
FL
RE: nitro
Don't let it idle in one spot for a long period of time, it could over heat...
The instructions that came with my truck was to use a 1/4 throttle on the first tank, in short steady accelerations then braking.
Heres what I went by.
http://youtu.be/if6LGYfKhqs
RE: nitro
thanks that really helped what nitro fuel should i use for the ofna ultra lx2 and will this car be able to travel throught highish grass thanks heaps!
RE: nitro
fuel depends on what you can get for your LHS as shipping fuel is insanely expensive.
anything but traxxas top fuel is good
Seriously though that stuff is terrible as it has WAY too much oil in it. When I used that junk after a run I would have to take my pipe off and drain it cause all the excess oil would get into the pipe and clog it up, and drip all over everything, and the engines occasionally would die out.
Last bottle of fuel I bought was O'Donnel and I liked it as I didn't have to clean out the pipe after every use, and the RC's ran consistently.
as for how high of grass I'd estimate 1-2 inches (max) anything past that is not recommended for any RC
My Feedback: (12)
WI
RE: nitro
Better get some fresh fuel to break it in. You will be dealing with the settings for a while, old fuel can be a problem. I'd try it once you broke it in, see how it performs. It may or may not be ok, depends on how it was stored.
RE: nitro
We use Losi Nitrotane (20 an 30) and have had zero problems. In fact, the only knock I've ever heard anyone say about it is it's clear. I feel priming should be felt and not seen anyway. ;-)
Oh yes!
ORIGINAL: redfisher1974
I've never owned a Nitro RC, Maybe time I should.
RE: nitro
oh great because my 1/10th scale cars i got an't able to get over the grass in the pattic so is this car lifted off the ground a far bit. and would it be doulbe the size of my savage xs?
