Taking Piston and Rod off of a crank
BC, CANADA
How do I take the piston out after i take out the sleeve? Now I dont know how to get the Piston and Rod off the crank[&o]
RE: Taking Piston and Rod off of a crank
take the back plate off and put the piston at the top of its stroke and then you should be able to pull the connecting rod off the crank and then the piston should fall out the top of the block
LA
if you took the sleeve out, it should be loose in there, just try and slide it off, if it wont work, take a screw driver, an rap a paper towel around the nose of it so you wont scratch anything, then just slide it off
