Plz Help - Plast Broken :(
Hey! Got bad news, When i tested the new Exhautus, One screw went out from the manofloid AND the front plast did tear in 2 peices.. which make me confused since the whole RC is depended on this part! ill put in a picture of the plast! There's 3 pic's of it.. U'll see whole problem in it.. Just not sure what to do. But Once the Exhuatus worked and the vehicle started. DAMN it was nice!!! but now im having one problem after another.. so any ideas how to fix these ones? and know what can of caused it? I think maybe its bad plastic
Just figured it out, must been from the accident when the battery went out and when i crashed it up real bad , and now when i drived it agian the crash became larger and now ... bam its broken... So i might go to the shop and buy a aliminum Suspension Holder today and the exhuatus screw must of been to little in.. but feel free to add a comment
Use Loctite blue if you wnat to be able to remove the parts later on. BONT use the red unless it's a permanent connection. I've used red on lots of things and usually to get them apart you need some sort of heat gun or other heat to weaken the loctite. Just remember to use blue, it's a threadlock basically, like superglue for metal on metal.
ahh , heh. I need to fix alot on my RC... now the suspension at front wont move... going to fix it right now but thx for the tips. ill go and try get Locklite blue tomorrow
