is it possible to.......
IL
Hey do you all think that it will be possible to change a team walbern nitro dragster over to electric? I like the rigidity of the nitro dragsters as oppose to the electric built ones.
TX
RE: is it possible to.......
im sure its possible, you just have to make the mounts for it, and figure out the gearing. but those electric chassis are plenty tough, and much lighter.
ORIGINAL: Igotntc3andrevo
Bottom line. If you are going to race a heads-up class, like Top Fuel Electric or Extreme, don't try to convert. Go with an electric chassis instead. If you are going to race an Index class or Bracket class, then a double reduction converted chassis can work for you. My 2cents. Hope this helps.
AC
IL
hey felllas thanks for the reply ok well i guess i will be going to a electric chassis i just like the look of the nitro the electric looks so plain to me. .......do you think that a team walbern prostock electric chassis coupled with a mamba max 7700 kv motor would be over kill (do back flips the second the trigger is pulled? and can i use nitro wheels on the electric dragsters i like the chrome star rather than the black rim.
The R2E uses 3 1/4" foam rears, but the double reduction gearing allows me to run the tall nitro tires. Not sure, but I'm thinking 2 5/8" foam is the largest diam that'll be easy to gear to on a single reduction gear chassis like the Walbern PS. At least that's the daim Team Walbern offers on its electric TF chassis, and 2 5/8" is what I'm running on the R3E-1 Bracket Camaro. Be sure to inquire if the larger tire set will fit completely under the body. Rules stipulate that for doorslammers running any other class except bracket.
Here's the link to Walbern's custom wheels: [link]http://www.teamwalbern.com/specialwheelstires.html[/link]
They "look like" 3 1/4" diam. Truing the foam down to 2 5/8" would be an option to ask the manufacturer about. Call Team Walbern and tell Paul what you want to do. He'll make the recommendations that will help you decide. Not sure if GMS offers a custom wheel. Don't see one in the online catalog.
Good luck.
AC
