RCU Forums - View Single Post - is it possible to.......
Old 11-20-2007 | 05:30 PM
ahr43
Default RE: is it possible to.......
ORIGINAL: Igotntc3andrevo
Hey do you all think that it will be possible to change a team walbern nitro dragster over to electric? I like the rigidity of the nitro dragsters as oppose to the electric built ones.
The rear clip on my R2E is mostly converted over to Team Walbern from OEM (Original Equipment Manufacturer). I use Team Walbern nitro parts - because they fit my OEM electric chassis. You probably have most of what I bought already on your chassis. Not sure why you want to stay with double reduction (spur/pinion - pulley/belt) over a single reduction (spur/pinion) electric setup. Unless you're like me, and that's what you've got and you have to make it work. I race double reduction; but it's not for everybody. My biggest challenge was modifying an electric motor mount that would not flex, resulting in separation/misalignment b/w spur/pinion. After I broke the code on that, the car began to perfom reliably. That was for a 2.5 car. Now that I've gone TFE, I'll have to re-engineer that piece again. The downside is I still have too much rotating weight-that kills a cars performace in RC drag racing.
Bottom line. If you are going to race a heads-up class, like Top Fuel Electric or Extreme, don't try to convert. Go with an electric chassis instead. If you are going to race an Index class or Bracket class, then a double reduction converted chassis can work for you. My 2cents. Hope this helps.
AC
