WLToys Extremo 4WD and RTR Buggy (1:10 scale) [UltraHD / 4K]
Fun drive test with this simple RTR buggy although what it calls it on the box doesn't match what is printed on the buggy which is a bit confusing. Transmitter has the obvious steering trim but also throttle rates so you can dial down the top speed (which is fairly good) for low speed crawling. Big suspension movement helps it absorb landings after taking some air but means when cracking along you have to back off in the turns otherwise it'll flip out. 2200 pack gives 15 mins of mixed driving. Rolled it a few times and jumped into a tree once and didn't get anything more than a scratch. WLToys seem to be knocking out lots of these variants on a buggy theme. Does what it says on the tin.
