Motor wounds...single, double, triple????
GA
I looked on the trinity website and saw thet a D5 7T single wound and a D5 7T double wound have the same RPM's and power.
What is the difference in single, double, or triple wound??? Which is better???
Pros and cons....
Pros and cons....
RE: Motor wounds...single, double, triple????
Single, double, or triple, simply affects when the motor reaches its max power. Single will reach it at a lower RPM then a triple. So in general, you choose the motor based on where you will be racing. Small tight track = single. Long open track = tripple. And of course there is a double, for the inbetween.
CA
so the double is average? I have a 12T double in my truck so is that fine for off road racing. I also have long asphault streets I do my speed testing on so is that motor good for these things?
The double is a "catch all" wind. Unless you just want to drag race or just want to ride a wheelie all day, stick with the double wind. It is the best for racing AND general bashing if you use the same motor for both.
CA
yeah I think that quads would have the more speed, and I never do wheelies with my evader with the double. I think it's cuz the front is to high. my brother has a rustler with the stinger motor in it and if you back up then go forward then it does wheelies
