Lunchboxer's TXT-1 project...
#2426
RE: Lunchboxer's TXT-1 project...
If it is completely packed, the grease get squeezed out... Would be interesting to pack it up w/ Tamiya's anti-wear grease, though.. those are stupid sticky!
#2427
anyone here using revo shafts for their txt?
can you please post a picture of the revo shaft in your txt? i'd especially like to see how the shaft is kept in place. afterall, the design of the txt's stock shaft is quite different from the revo shaft, isn't it?
and just to confirm that the image below is the right one, is it? any addtional parts need to be ordered for the shaft to fit?
thanks! got my txt in march. till today, it hasn't ran an inch... it's lacking skid plates. it's lacking servos. it's lacking a novak hv maxx 6.5. it's lacking lipos! and of course, it's lacking monstrous drive shafts!!
#2428
CA
Lb has one on the rear of his TXT after his "accident"
I have some that im goign to swap in when my shafts break..
update on the TXT: currently charging for its long awaited run! thanks again LB for the parts
#2429
"Accident"?!?! [:@]
It will be a simple direct fit (with minimal modification needed, although you do need some.. which was documented in the thread..)
Glad that you got the TXT up and running! No problem w/ the parts.. glad that you can use it.. although I am still preaching to get the aluminum parts.. hee hee..
#2430
HELLO ALL! I've been very very busy with school and helping run a business.... anyways, lets talk some TXT-1!
mine is loads of fun to play with, and even more to work on :P. but the steering is funky, and has never really worked right... sometimes it only wants to crab walk... and I can't seem to get it to properly work in true 4x4x4... but hey, whatever....
also, i have decided that the current 80 oz/in servos just wont cut it, at all... i need some much powerful ones....
#2433
CA
yeah ill be getting them as soon as i find time tooo.. i still haven't ran it yet.. found some time on friday after class to get the chargers set up to charge it and now its just still there now waiting to be ran.. next available time would be tuesday... hopefully.... barely even have time to come back and wander the forums like i used to..[]
ORIGINAL: Lunchboxer
"Accident"?!?! [:@]
"Accident"?!?! [:@]
#2436
They are not for my TXT.. I was just buying stuff for Arild.. (he is based in Norway)
I use NewEra skids and Tamiya alloy holders.. unbeatable combo...
#2437
CA
I can't find the aluminum cantivilers, and I sold the pair I had....
I don't wanna get more plastic ones cause they will probably strip after awhile.
What size are the 4 link rods again? I thought it is 6-60 but I'm not sure (with 4-40 threaded inside for the ball connectors)
#2441
CA
OOPS LOL.....
Didn't Tamiya make aluminum shocks for it too? They still make a couple things for it, I know that...
#2443
Arild's Integy axle holders / skids....
The axle holders are plenty beefy..
I'm really looking forward to this build
#2444
I don't think you would have problem.. the axle holders looks to be pretty strong..
The skids might be a little bit thinner compare to the NewEra.. but should still be okay..
#2445
#2447
CA
sup LB and the gang. one of the few times i get to check out the forums. good the see the txt thread is still going.. too bad my txt is broken again... don't know what i hit but i broke one of the upper link mounts..[&o]
arild the TXT is one tough truck so bash it hard! i miss running mine, even when its fixed i just never have time anymore..[]
#2448
Did you use the brace?? I never had problem w/ the upper link mount.. I ran the aluminum brace from rc4wd.
Post some pics of the damage!!
