Lipo battery recommendation for Mamba 5700
TN
RE: Lipo battery recommendation for Mamba 5700
http://www.a123racing.com/html/starterkits.html
Much safer than Li-Po, useable for 1000+ cycles. Cheaper than a Li-Po + Charger + Balancer. 15 minute re-charge.
Perfect batteries if you ask me, unless your chassis can't accommodate the form factor.
ok, this is kinds a newbie question, but i'm still a newbie so..... those packs are 6.6 volts instead of 7.4? whats the difference going to be?
TN
Don't be turned off by the voltage different. These packs hold their voltage under load as good if not better than any other battery.
My buddy with his E-sav has three different sets of batteries. (2) Venom 4600, (2) GP3300's and (2) A123 6.6v's. The A123's outperform both other sets by a long shot. He's runnin S600's and 22t pinions and can wheely all day with the 123's but can even get the front wheels off the ground with the nimh's. A123's can simply provide more power despite their lower voltage.
After using my 3s and my friends 2s packs, I simply can't imagine getting any other kind of batteries.
TX
Don't forget too that the A123's weigh a lot less than Nimh, so although not as powerful as Lipo, they will still perform better for their voltage than nimh.
My Feedback: (23)
WI
ORIGINAL: Slo-V Flyer
those a123 cells seem very interesting. Does anyone here run them? How do they work in a Novak with say a 6.5 motor?
VA
I also have a mamba 5700 and I would buy some a123 if you could charge them without a 12v power source. does anyone make a converter from 115v to 12v?
I have a HPI Sprint 2, which can only fit a stick pack. Thats why I want to go with the Lipos. I really want a 3s lipo pack, but cant find any that are make for cars.
NC
I've been running these for about 6 months and have been happy with them. [link=http://www.maxamps.com/products.php?cat=13]Maxamps Lipo[/link] I have the 4000mAH 3 Cell version, they fit in stock battery trays and should work with your car. The a123s look cool but I would mind the low voltage vs. LiPo and you will definitely notice a loss of performance due to this. If you go with the a123 at least get the 9.9V version or you will not be getting near the performance you could out of your 5700.
