Official E-FIRESTORM thread
#7777
RE: Official E-FIRESTORM thread
ORIGINAL: DarksideVR
Take that HPI thread. lol Is this just random trash talk or did I miss something? either way I love it. lol No way the E Firestorm is definitely superior. hahaha
ORIGINAL: Dadx2mj
With refined driving skills, the Rustler puts a whooping on that e-firestorm. Its about driver skill.
You didn't miss nothing Darkside, we just won a free precious comment out of nothing to light up our day.
Red is right, it is the post of the week! LOL
I loved!
#7778
ON, CANADA
ORIGINAL: Dadx2mj
#7779
Banned
These posts showing clear disrespect to my replies would clearly validate deletion of posts if I were the moderator here. Try checking out the manner to which the Traxxas forums are maintained. You may come away from it learning a thing or two about proper post etiquette!!
#7780
ON, CANADA
I think we have a new candidate for post of the week.
Its called having fun....relax. I don't know what other kind of replies you could expect from your out of the blue post other than manufacturer bashing. There are 308 pages of precedent for this to be a very civil forum.
If you look to the bottom right of the posts there is a 'report' option where you can contact a moderator regarding our behaviour.
#7781
1 Post
ORIGINAL: Dadx2mj
#7782
Banned
ORIGINAL: redfisher1974
Traxxas forums practice proper etiquette? You Crazy...[&:]
ORIGINAL: Dadx2mj
#7783
ON, CANADA
Again, relax, Red was being sarcastic. I am certain he knows that Traxxas moderates their forums well.
There is always the button on the bottom right corner for you to use here. The mods do their job here too. I've used them several times.
#7784
Banned
ORIGINAL: nitro-rob
#7787
Just curious...
Does anyone knows the amperage range of original and version SV2 Sidewinders ESCs ?
Actually would be nice to know how the role new 1/10 CS ESCs Amp range for comparison, like Mamba Max and Mamba Max Pro.
Why do they hide this info?
Interesting to see that the new Sidewinder SV2 chart shows compatibility with 3S Lipos up to 5700KV motor!
If that is correct, instead of changing my motor for 4600, I could just swap the ESC and keep the faster 5700 with 3S...
Seems like a good speed project! : )
#7788
#7789
Regarding your links, it seems both are for the same product, no difference between them.
I think there are people here using this wheels with E-Firestorms.
Not sure if it needs any mod to fit.
Saw a vid on youtube some time ago of a previous mounted set of wheels, from same brand, that required drilling larger wheels holes to fit.
Some time ago I got a set of rear and front Jato wheels for my Storm, but actually only the rear wheels have the correct hex hub size as Jato uses bearings in the front wheels.
This way I advice you to get 2 sets of rear wheels to fit the Storm.
#7790
ORIGINAL: Velociraptor73
Just curious...
Just curious...
#7792
MT
the links look the same to me. As long as it is a 12mm hex it will fit back or front. some of the older nitro had front wheels that had bearings in them, you don't want those. you may need the traxxas hubs cause the traxxas and e firestorm ones are different. looks like I am a little slow
#7793
You will have to change the hubs to traxxas or drill them out.
Maybe that's why I didn't need to drill.
#7794
VT
ORIGINAL: AL3xGR
I think 60A(they say about 2/3rds of the power of the MM)
Just curious...
Just curious...
the lug
#7796
ON, CANADA
Just changed my oil in the van outside in sub zero temps....got it done...[&:].
#7798
Hey guys,
Finally got the time to test run my new eFS.
First impressions:
Apart from a low running time (+- 10min) with NIMH 3300 7.2V, I am really happy.
Coming from 4WD buggy, a little surprising but plenty of fun.
Plenty fast for me; can't imagine driving that thing on LiPo 2S.
Looking forward to buying a new NIMH 5000 MaH 8.4V for extended run time.
Will I get more run time? Will it be a little faster?
Will see and get back to you.
Will also look into spare (front and rear A arms just in case...)
Enjoy the WE,
V
First impressions:
Enjoy the WE,
V
#7799
With 8.4V 5000mAh you should have more acceleration (mAh) and top end speed (voltage)
The only draw back is the bigger weight the heavier battery will put in the suspensions and power system.
With more mAh you will also get longer run times, probably around 20-30% more if I'm right.
Regarding spares, I never had a broken part in my storm so far.
And I had some ugly perpendicular crashes in sidewalks...
The only part I had to change was the servo saver, always getting loose after some heavier accidents (and eventually in the soft ones too).
Back to the new Sidewinder SV2, I keep thinking how can it be OK with 5700 if the Mamba Max use have overheat problems in the same motor?
Was it an ESC issue instead of motor that was fixed in SV2?
Will have to wait for someone to try it or ask Castle support, if they are kind enough to give a straight and sincere answer.
Will try CC support to see what comes back...
#7800
