The Official Losi Desert Truck Thread!
#1026
WA
RE: The Official Losi Desert Truck Thread!
Well last night I lunched a idler gear. We are half way home from Arizona and in a RV park on the Oregon Coast. Got the DT out to show our friends. It was a little slow with my paved oval track program, so I took it to the laptop and turned it up all the way. Came back out and on about the third pass it cleaned some teeth off the idler. Today I put in a spare and detuned it, tested it and put it away. Got to look for the medal idler. Part No?
Needs tires and body when I get home.
Chris
Sidewinder +4600.
Switch tires.
Chris
Sidewinder +4600.
Switch tires.
#1029
WA
ORIGINAL: powerslider
Robinson Racing #9402, I just got one from Horizon hobby this last week. Say goodbye to idler gear problems....[8D]
#1030
Last night I actually broke a rim, one of the Losi stock rims with an HPI Geolander on it. Was driving along, bashing in the back yard, and suddenly the wheel goes flying. I thought that the nut had come off, but actually, the hub part of the wheel itself sheered off and the rest of the wheel and tire went airborne. haha
#1031
ORIGINAL: goedmonds
Do you have to run a little grease on the metal idler? Chris
Yes I would grease the gears, metal on metal is not good without lubrication so the top gear and idler need lube
#1032
WA
ORIGINAL: SquireSCA
#1034
Never let a newbie use your brushless truck. I let my friend and he ran into a cement wall at about 20mph. Destroyed the Kickplate, Bulkhead & Brace. It';s a good thing they are inexpensive to replace. I said, "easy on the steering and very easy on the throttle."
Is there any maintenance needed on the diff? The truck runs very fast and smooth, but there is a bit of a rattle coming from the rear.
Does anyone make a front bumper with a pivot and a shock absorber. I have a design in my head, but want to know if there would be a market for it.
Ian
Ian
#1035
The RPM bumper flexes alot but is not as cool. I run them on both my trucks. Got my $28 Zippy Lipos today... 4 of them, Wow, these have some punch. Heard good and bad bout these but all charged and are balanced. I might buy more and be able to run my truck while I drink a whole 12 pack, Nice.
#1037
One of my RPM bumpers is a year and a half old still going. I have a rear bumper from T-Bone (i think) and they warrantee it if you can break it. I think I bought it on ebay.
#1038
Hi i got my losi DT yesterday.It is a great little truck but to be honest it isnt fast enough for me as i am used to nitro and petrol.Now i am an electric noob and want to make this brushless.I wont be running lipo so is it just a case of me buying one of the losi brushless motors and useing the electrics that came with the car or would i have to buy the whole package of motor plus ecs and stuff?Thanks for any info,
#1039
WA
ORIGINAL: martin34
I have Castle Sidewinder and 4600 motor and run just 3300 NiMH batteries. It rocks. Get the interface cable so you can program it with your laptop. Chris
#1040
You haveto buy the whole package... esc and motor. If your looking to save some money get the Castle Sidewinder.. I'd get the 5700 too. I have both the Mamba and the Losi and both are excellent.
#1041
My Feedback: (67)
Depending on what you surface you will be running on, you may need at least a different set of rear tires. The stock ones are okay until you switch to BL, then you don't get much grip on most surfaces. I personally think it's because the truck is already pretty light and the stock tires lack bite, I run lipos also so I'm sure that exacerbates the weight variable. I'm running the 4600 Sidewinder combo w/ 25-30C 4000MaH Lipos, tuned way down and you still have to be super easy on some surfaces. It has a tendency to just spin out from the get go, but a lot of the BL DT guys on here have swapped to some tires with more bite and seem to like it. Hope this helps. Also you can pick up either 1/10 Sidewinder kit (Motor and ESC) for around 130-140.
#1042
Thanks guys it looks like i will go for the 4600 sidewinder.I dont need it to be crazy 70mph fast but around 40mph would be good.Will it be easy to set up?
#1043
Does anyone on here run one of the ezrun brushless combos?I have been quite a bit of good reviews on them over here in the UK and i can get an 8.5t combo for £80 whereas one of the better known combos will set me back about £130.
#1044
FL
ORIGINAL: martin34
#1045
ORIGINAL: martin34
In this thread, http://www.rcuniverse.com/forum/m_8457415/tm.htm, 82% of respondents say it's worth getting.
#1046
WA
"Thanks guys it looks like i will go for the 4600 sidewinder.I dont need it to be crazy 70mph fast but around 40mph would be good.Will it be easy to set up? "
Martin - Also order the USB PC interface cable. You can build and save profiles. It is also much easier to program the esc. I could beat most of the VXL Rustlers on our track because they could not control their power. Chris
#1047
My Feedback: (67)
I have an 1/18 EZ Run brushless on my mini-DT w/ a castle cm20 4200kv motor and it flies! I have over 30 runs using 2s lipos on this set up and haven't had a problem, it cost me around 50 dollars US. The programming card works well and it makes an awesome mini off-roader, my ESC is ice cold on 2s lipos @ 1750 MaH and a 35c burst 25c continuous. Also my manual for my EZ run esc says it is waterproof, I wouldn't try it but it was clearly stated in my manual. I would go with the ez run if you can pick one up for cheap but remember the Castle Sidewinder mini combo is around 100.00 US and is definitely a good combo w/ the motor and esc.
