Can I reverse this screw-up?
RE: Can I reverse this screw-up?
ORIGINAL: MF2MM5700
Yes it will. I tried the brake fluid on my Jconcepts body and it not only hazed the lexan but made it so brittle it would tear very easily.
I let it sit in brake fluid over night like the tut i found said to. The next morning most of the paint was of but when I pulled it out and rinsed t of it was cloudy and tore with the slightest movement.
I have tried DOT 3 several times and never had a problem.
