New M-Chassis from HPI !
#176
RE: New M-Chassis from HPI !
My bad you are right the rear diff cups are plastic and the front are metal. I looked at the Brama briefly and it seems to be much less sturdy then the Cup racer but I mean I haven't seen it in person so Ican't tell for sure. Either way Iput my cup racer under the stress of the sidewinder 5700kv combo and its holding up real well so far. Cheers, raz
#177
OR
ORIGINAL: ro.sniper
#179
NY
just ordered my cup racer, have some parts around and just wondering if they will be ok.
stuff on hand
20T motor
27T motor
7.2v 3300 mah nimh
HPI EN-1 esc
and futaba servo
I also have a TA 18R esc I can use
will this get me up and going?
what motor?
stuff on hand
20T motor
27T motor
7.2v 3300 mah nimh
HPI EN-1 esc
and futaba servo
what motor?
#180
ORIGINAL: popdada
stuff on hand
20T motor
27T motor
7.2v 3300 mah nimh
HPI EN-1 esc
and futaba servo
what motor?
stuff on hand
20T motor
27T motor
7.2v 3300 mah nimh
HPI EN-1 esc
and futaba servo
what motor?
If you have a camera post some pics so we can all admire your handywork.
#182
I'm running stock gearing on the 5700KV but it seems to be getting hot quite fast so I need to go down on the pinion and up on the spur. www.gearchart.com can help you out with that. I'm thinking a 24Tpinion and 67Tspur should be a bit better.
#183
ORIGINAL: popdada
what gears are you running with the 19T?
ro.sniper I like that gearchart. That's some great info.
#184
I just finished building this 240z kit. Its my first and it brush painted. It also has a 19 turn LRP GT3 motor in it. Have not driven it as yet though.
#185
CA
Wow! That is really nice! Your color choices are unique and love the contrasting stripes! You should get that thing out in the sun for some nice photos, would really look real!
Great job!
Cheers,
Skottoman
#189
CA
Hi, I have been having some ESC heating issues. Shutting off from thermalling. Basically because I paired a 17T motor with a basic Tamiya ESC. (I think it's designed for stock and maybe down to a 23T motor)
This ESC is rated for higher wind motors and was overheating with the cockpit in the car and having no heatsink. So.... I removed the cockpit, made a heatsink out of aluminum tape, and cut a vent opening in the cowl of the car.
Amazingly enough I can now run an entire battery through, and the ESC stays cool. It really works! I didn't think it would, but so be it.
So if you are using one of these Tamiya ESC's and having cooling issues, try this. It actually works. I'm amazed.
Cheers,
Skottoman
P.S. Hey Donfartist.... If you haven't glued your tires onto your wheels yet, I think if you sprayed the wheels silver it would really make that car "POP!"
Cheers,
Skottoman
#190
I was running my Datsun up and down the street this past Sunday and my neighbor came out to see the new car. He has had an LSTand HPI Baja 5B in the past. He immediately wanted to get one and he had me help him write up a list of stuff he needed to get one in his stable. Now he said he is going to start working on getting some of our other neighbors to get Cup Racers as well. The infection is spreading!!
#191
CA
It's funny, I've read on other forums about people having problems with their Cup Racers. I haven't had any problems (except some ESC heating issues I took care of). I've run probably 12 battery packs through the thing, wore out the stock tires, and are almost done with another set of HPI X-Cut tires.
Running a 17T motor and all the rest is stock.
Great little car!
CHeers,
Skottoman
#192
My cup racer sounds really good without the wheels on, but when they or on it sounds rattly... I'm not sure what it is, but I think my tire may be severely out of balance.... how do i get them in balance... I also remember that I forgot to glue the foams inside... that probably has something to do with it no?
#193
CA
Nice job! Did you paint the car from the outside?
ORIGINAL: Donfartist
#195
CA
People think Iam crazy but Ikind of like painting from the outside as well for scale cars anyways. It just look so much more realistic that way. Even when it gets scratched it just looks like realistic body damage. Again very nice job take some outdoor shots if you can Iwould like to see it in sunlight.
#198
Hey guys new to the boards here, but not to r/c. I use to own a few back in the day. (hpi R40, Hi Savage, Kyosho Inferno mp9) Anyway, Ive been missing the hobby for sometime now, and Im thinking about picking one of these up to toy with. Anyway I wanted to know what you guys thought about these for drifting. Its just something I want to have fun with, do some mods, and kind of work myself back into the hobby while I save up for a 1/10 scale nitro next year.
Anyway thanks for the help in advance, and look forward to joing the owners club..
#199
Looks like HPI is starting to stockup their HopUps for the Cup Racer. My wallet is starting to burn in my pocket.
fade2black85 - Have you seen the Drift Version of the Cup Racer, or were you going to get a regular version and kinda mod it towards drifting?
#200
ORIGINAL: yama86
