Does it matter which plane I edit?
My Feedback: (9)
IN
I am curious, if I was to edit the parameters of two drastically different planes to the same specs, would they then fly the same? Like if I edited the Fundango electric plane and the Cessna to the same specs like my giant scale Edge 540. Would both planes then fly the same or would some parameters of the original still remain?
Thanks,,,basmntdweller
RE: Does it matter which plane I edit?
I don't think you could spec either of those planes to the same as your edge, or each other. Using AFP you can't change fuse length , tail moment id pretty important as to how an wircraft flies.
