G3 and Futaba 9C
OH
G3 and Futaba 9C
I just recently purchased a 9C.
I have a G3 simulator that I tried to hook it up to.
I can't make the simulator recognize it.
I have started the G3 launcher with the radio turned on and plugged in.
Can anyone suggest what I'm doing wrong?
Thanks!
JLK
Thanks!
JLK
OR
RE: G3 and Futaba 9C
Go to the "Controller" menu, choose "Select Controller." You should see two entries, one for the interlink and one for the 9C. If you only see the interlink in the submenu, then the most probable cause is the connection between the cable and the interlink. Make sure it is well seated.
OH
jaafit,
Thanks for the reply!
I'm still afraid no luck.
I have made sure I have good connection but still only have the one controller recognized.
Is there anything else I should try?
Thanks!
JLK
Thanks!
JLK
OR
Make sure that the xmtr is in PPM rather than PCM mode. See pages 10 and 163 of the [link=http://12.156.2.54/downloads/RF%20G3%20Help%20Doc.pdf]RealFlight G3 Manual[/link] for more info.
