RCU Forums - View Single Post - G3 and Futaba 9C
Old 08-22-2005 | 01:51 PM
jaafit
Default RE: G3 and Futaba 9C
Go to the "Controller" menu, choose "Select Controller." You should see two entries, one for the interlink and one for the 9C. If you only see the interlink in the submenu, then the most probable cause is the connection between the cable and the interlink. Make sure it is well seated.
