Redcat Rampage MT Hitec HS805MG steering servo
My Feedback: (10)
IL
I know that this servo is not a direct fit in the MT, so what mods have to be done to make it fit? I have the dual servo set-up. The right servo can get mounted to the chassis because there are two additional holes, but then the throttle/brake servo plate hangs off and can not be mounted on the right side. The left servo can be mounted on the right side of the chassis and battery box, but then hangs off the left side of the battery box and there are no additional holes on the left side of the chassis.
Are there some kind of adapters available? I found that there is an aluminum futaba servo mount set from Redcat, but I'm not positive if that makes both sides mountable? It only looks like the right side can get mounted with the three pieces that are provided.
I have been going bonkers trying to make it fit and searching for pictures/info of what is needed.
Any help would be appreciated.
