traction on loose surfaces--I need the adjustable diff?
NJ
I think I know the answer, but when accelarating on loose gravel, one wheel spins faster than the other, and the truck doesn't launch as straight as I'd like. A little of this is understandable, but on some surfaces, things are barely controllable. For those who have the adjustable diff, did this decrease the problem. Did anyone lock up the diff to get both wheels spinning evenly? (I know some of you used thicker diff oil, but I'd rather just have things really locked up--unless there is a drawback to this)
1 Post
RE: traction on loose surfaces--I need the adjustable diff?
I have the adjustable diff 0-90% locked. I found in wet greasy mud it was much better, but on a dry dusty track it was so different as to be undrivable it would launch off then just spin around for no real reason. unlock the diff and all was well again.
This was on an MB, i'm gonna lose the adjuster ring I think and fit a normal diff cover so i can get rid of the alloy spacers under the diff mounts needed to fit it in.
Col.
Col.
I have the FG Twin adjustable diff in my Monster Truck.....heaps better than the factory diff.
I just cut a small slot in the chassis so the diff ring would fit....better than fitting spacers.
The standard open diff is just fine (with an alloy case, of course). The only locking differential worth its price in off-road cars is the new visco diff. Expensive, yes. But no need for adjustment and silk smooth action. I don't know why FG is telling it's for on-road only. It's the best there is.
NJ
ORIGINAL: kiora
Col.
Col.
I locked the diff in my mt and it was undrivable. The slightest touch of throttle and it would spin out. I would lean towards the adjustable diff since locking it completly is not ideal.
1 Post
Im guessing it was because both wheels were spinning/powered to the samedegree, but only one had any traction.
I'll stand corrected though
Col.
Col.
NJ
So someone's gotta make a limited-slip differential (although the better answer is a quality 4-wheel drive system--but that's another thread). Oh well.
I will go with chevyman_de here. I have had the opportunity to try both a onroad (sportsline) and a MT with the selfajusting 4 way diff (viscous version not released at the time)
It is selflocking/unlocking from 0-85% I think (perhaps higher than 85% can't really remember)
I have no special skills in driving but what a difference. Most FG shops says that it is only an aid in driving, not a solution, but I'm more leaning to the "solution" part.
If I ever need to buy any other diff upgrade besides getting rid of the stock unusable plastic one (why was that even invented in the first place..??) I would surely go for a self ajusting or viscous version. The 4-way diff is almost the same price as the viscous one.
Yes pricy but hassle free and perhaps the best upgrade you can get.
EDIT: Spelling
EDIT: Spelling
NJ
ORIGINAL: sasquatch1976
I will go with chevyman_de here. I have had the opportunity to try both a onroad (sportsline) and a MB with the selfajusting 4 way diff (voscous version not released at the time)
If I ever need to buy any other diff upgrade besides getting rid of the stock unusable plastic one (why was that even invented in the first place..??) I wouls surely go for a self ajusting og viscous version. The 4-way diff is almost the same price as the viscous one.
Re-hee-heeeeaaalllyyy..... That's good info Allan - you just rearranged my shopping list completly there!
I've been playing a lot (!) this weekend and I gotta tell you - I'm kinda sick and tired of having to be oh so gentle on the throttle everytime I run on a loose surface when accellerating. Buggers me senseless and spoils the fun all together.
If that viskos diff contains the holy grail then I'm prioritising it above any alloy hop-up!
Cheers!
ID
I just bought the visco diff. I've been running the Technokit Auto-blocking but I've never been very happy with it. I don't think it provides very much locking action. I raced lasted week agains a car with the visco diff and the difference was amazing. We'd exit a turn and get on the gas and I'd diff out and smoke the tire while he just drove away. I can't wait to try mine out. I'll move the Technokit to the MT.
I have the visco diff(FG#8600-$330.33 ) and yes it awesome and no modificatons are neccessary other than you must omit the copper washer on the drain plug. Now that I have lifted my diff with krikke diff plates I could put the washer back on. BTW the visco comes with on road axle/ball cups if yours are in good shape you can re-use them. I have had no problems with rampant uncontrolability as with the four fold(FG#8501-$273) adjusted too tight. Yes the stock diff with the plastic is very notchy (at best) the aluminum upgrade(fg#8484-$76.18) is better but it still will not help your tracion situation. Good luck! Just so they are all here the single fold(FG#8485-$172.25) And the stock with all alloy(FG#8483-$151.45)
make it to 4wd, thats the best solution. Mine is cornering on throtle and no sliding.
If you put some time , I'm sure you can make one.
I don't sell mine but you all welcome to see the design.
it is not detiled yet. but soon I will post more picture.
mostly used fg parts.
this parts I make is much cheaper than putting option parts or diff.
http://fg4wd.tripod.com
King of Kong, thanks for your generosity I plan to build my own 4WD conversion and different Ideas are most welcome. I don't plan to sell these kits, to me RC is my hobby and I never want it to become a job.
I look forward to seeing more of your conversion and any problems you may have had.
Anyway, Thanks again
Ghydda: Yes.. Holy Grail for sure. (Love the Jim Carry laugh hehe)
Viscous diff or 4 way self ajusting for me also.
ON, CANADA
I would try 120,000 or 300,000 diff lock and see how you like it. I use 120,000 myself and I'm very hapy with the results. $10 is much better that a few 100 $$'s
ID
ORIGINAL: SELWA
My Feedback: (9)
This stuff works wonderfully! (if you are one of the few who can still get into your diff. housing without a Dremel) [&:] But be sure to order two because a single container is too small for our size of differential. BTW, DON'T get any on your hands!!! [X(]
Thanks, Cyberfyn!
Thanks, Cyberfyn!
Im no expert on diffs, But i have learned from the knoledge and info from good racers That a quad auto locking diff and the viscous diff both work by Torque and thats why they are best used onroad with a good set of warmed tyres and loads of grip you diff out and torque is generated and they automaticlly lock, I don't think you would get that kind of result on a dusty lose surface so it would be of no great benifit, I would and have gone for a manual adjusting diff for offroad use, It's by far better than a stock diff more control and use of power on my leopard race. But for onroad people the quad diff is great but the new viscous diff would repay the new owner with a jolly good smile time after time they really do work well.
