Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Giant Scale Cars
Reload this Page >
What’s the Best Air Filter?
RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Old 08-24-2008, 08:20 AM
nzkiwi1975
Default What’s the Best Air Filter?
I’ve got a Cone Style Air Filter, I’ve read that they aren’t the best & may let very small parts of dust through.
Any suggestions what would be the best filter to stop any fine parts through??
Old 08-24-2008, 08:59 AM
Lars from Norway
Lars from Norway's Avatar
Default RE: What’s the Best Air Filter?
Any kind of foam filter would be better than the K&N-style filter(these are mainly for onroad use),use a pre-filter to get even better filtration
Old 08-24-2008, 12:01 PM
Foxy
Foxy's Avatar
Both the HPI Baja and FG Baja stock filters are excellent.
Old 08-24-2008, 12:04 PM
Kemo
anything foam is great. K&N filters are for bling factor... shelf queens and such.
Old 08-24-2008, 12:53 PM
Wolf[NL]
High Performance Airfilters by TWIN AIR from rntuning: http://www.rntuning.nl/
Very good filters
Old 08-24-2008, 11:12 PM
Vinman02
Here's my current setup:
DDM filter with the stock Baja oiled foam filter and cage inside.
Works great, no dirt gets by and is a heck of a lot easier to service when compared to the stock setup.
Vince
Old 08-25-2008, 01:24 AM
turbodremz23
My Feedback: (16)
turbodremz23's Avatar
very nice vinman
Old 08-25-2008, 01:26 AM
jasrx
i run a standard FG foam filter and a outawears cover ..
Old 08-25-2008, 02:03 PM
hellya
hellya's Avatar
I run a firehammer filter and a baja filter .....same design ...inner and outer filter.......dual filters
look at the dirt it keeps out[X(]
Now look at the inner filter clean as a whistle
ID:	1019223   Click image for larger version
ID:	1019224   Click image for larger version
ID:	1019225   Click image for larger version
Old 08-25-2008, 02:22 PM
nzkiwi1975
Vince, Nice work.
I’ve got a tall V-Stack with Cone Style Air Filter & Outawears cover (all came with truck)
Going to look at using existing Cone Style Air Filter with Baja oiled foam filter and cage inside & Outawears Cover.
Should this be ok??
Old 09-13-2008, 08:49 PM
Dirby
you asked what was the best air filter/
what truck are you running.
if you are running a Baja than the stock airfilter properly oiled with a tgn outer filter and outerwares filter cover.
somebody said something about a di fferent filter that was easier to put on and take off.
Do you want ease of removal and instalation or do you want the best filter for your motor.
the stock one does protect the engine best from dirt and sand.
yes some of the other air filters are easyer to use but they don'y protect as well.
Dirby
Old 09-14-2008, 04:05 PM
NitroNate
NitroNate's Avatar
Do you guys that own Baja 5bs find it a pain to put the OuterWear pre-filter(drawstring type) over the stock filter or am i doing something the hard way.
Any suggestions on how to put them on easier?
Old 09-14-2008, 04:20 PM
Apache-
twinair ones / rn tuning are top products.
It depends but foremost on a good oil you use and also how well you pay attention when oiling it...
I think this is way more important then the type of filter.
Old 09-14-2008, 05:23 PM
Dirby
ORIGINAL: NitroNate
Yes they are a pain to get on.
just rotate the filter assembly while putting the cover on.
little on than rotate put a little on than rotate.
keep doing this back and forth and it will get easier as you go along.
this is the Best filter system there is.
Old 09-14-2008, 08:27 PM
budman10
stock with a outter wear thats a baja right
Old 09-15-2008, 04:02 PM
Dirby
yeah it is a Baja.
Old 09-15-2008, 11:31 PM
SELWA
SELWA's Avatar
Best setup for an FG was the stock filer with the FG cone cover over that. (FG#6464/2) $20 for the cover and you are set. I've had this setup al year long through rain,snow,dirt,mud and dust. I ran my Leopard Race once with 4LBS of mud on the chassis and nothing when into the air filter. Regular foam and fabric covers would not be able to do this.
