1/4 -1/5- 1/6 scale solid axle?
WA
does such a thing exist that can stand up to 1/5 scale abuse? as in mass produced or custom machined i have been looking for about 2 weeks and other then tamiya and axil (sp) i havent really seen (wheelie king) any thing in a live axle i really wouldnt want to go the custom machined rout ( as i dont have the knowledge or skill nor $15k for a set lol)
NY
RE: 1/4 -1/5- 1/6 scale solid axle?
I believe RC4WD.com has a couple 5th scale axles. They are not cheap, as they are made to be "scale" versions of real axles. But I would bet they are tough. They look very well made. I have a few parts for other vehicles by them and they all are really nicely made.
WA
ORIGINAL: Soloratov
BC, CANADA
ORIGINAL: Soloratov
I believe RC4WD.com has a couple 5th scale axles. They are not cheap, as they are made to be ''scale'' versions of real axles. But I would bet they are tough. They look very well made. I have a few parts for other vehicles by them and they all are really nicely made.
Awesome, just looked at their site and $650 for front and rear is an awesome price...pay that for a motor and pipe. I've been looking for solid axles for my FOFF jeep build..now thanks to you i've found them thanks a million
WA
for future referance for me and others...
front
http://store.rc4wd.com/products/The-...xle-Front.html
silver
http://store.rc4wd.com/products/The-Ultimate-Scale-Yota-1%7B47%7D5-Axle-Front-(Black).html
black
rear
http://store.rc4wd.com/products/The-...Axle-Rear.html
silver
http://store.rc4wd.com/products/The-Ultimate-Scale-Yota-1%7B47%7D5-Straight-Axle-Rear-(Black).html
black
front
silver
black
rear
silver
black
WA
well i got to come up with the cash for a rampage mt and these and ill be able to come up with some thing....
(looking @ about $2k+ for full setup as i would only do this build with dual metal servos in front and rear hopefully these would handle 2-3 hp...
you have to understand i have wanted a gas/nitro powered rc monster truck since i was about 12 or so after seeing my cousins 1/5 electric monster back in the day and well i have always liked true to life models so well buying a rampage mt with its stadium truck style suspension just aggitates me...
this is what is and has been rattling around in my head for the last few weeks as i have been assembling it in thoughts
so my initial thought is rampage mt pro
(this way i should be able to make a few $$$ off the front and rear metal parts as well as the stock drive train)
custom aliminum chassis allowing quad steering servos (dual in front and rear)
yota 1/5 axle (front) in both the front and rear still havent found a 1/5 scale transfer case though the stock 1 may work
still havent decided if i want to run a channel cut off or run dual steering all the time... (tighter turns)
i hate pistol grips so i would be running either a 5 or 6 channel flight controler like a spektrum
still thinking on other stuff would need 4-link..... so i guess an upped motor will be amust as i dont think the fulie 3.0 would provide the power.....
BC, CANADA
ORIGINAL: bentley marshall
ive been waiting for some one to make something out of these ...
as long as these can take the power of an OBR full mod then a pair will be going on my FOFF for sure...my build is on hold now until i can get some more info about durability and diff, are they sealed??...I"ll be totally stoked if these can handle the ponies
BC, CANADA
I sent them an email asking a few questions and whether they'll handle the stress an OBR 27.2 full mod w/vrc pro and with 5b paddles will dish out.... Can't find any info on the diff or any spares so asked that too. See what they say.
WA
let me/us know what they say...
i see the aliminum xvd failing bfr the diff gear shread i see you having to run a planitary gear to solve that issue bfr you would ever have to worry about the torque shreading the gears
my thoughts are that with your setup your going to be breaking more axle's then any thing else if you build it properly.... torque + lots of friction... not just heavy landings
(refering to xvd not the actuall housing)
i emailed them, ages ago they told me they were made to be used in a electric scale truck so im not sure how much hp you could put thru them
WA
its not the actual horse power rating your worried about but the amount of torque that is going to cause the issue with the diff gears if there not meshed correctly
BC, CANADA
looking at the diff cups doesn't instill confidence...next to the axles they look to be only 6mm[&o] which is the same as a savage...hope I'll hear something from them today but i reckon Bentley is right in saying they're not designed for us gassers...if only they'd make them with beefier internals
there is this site that has rear ends dont know how much they are tho http://www.firstquarterracing.com/index.html
I have a set of these for a 1/4 scale project. I think they would be OK for a crawler, but nothing beyond that. The ring and pinion is very small. The units are very well built though and ridged. I have a thread on my forum about them with pics. I definatley recommend them at that price.
I've been trying to purchase a set of those 5th scale Yota Axles for a year now. Unfortunitely the response is always the same..
we might get more made in 2-3 weeks, no ETA yet
we will update the specs once we have more made
WA
ORIGINAL: motionmachine
WA
with a gear ratio of 2:1 i don't see these things being good for anything but rock crawling and a street car unless you paired it with a planitary as i said above... which eh isn't seeming to be much of an issue as with 4wd and 4ws solid axle i wouldn't be using it a trophy truck for bashing (i was joking about scratching them) qsl thanks for those pics....
BC, CANADA
here's the response i got...
Hi Julian,
No they are made for electric motors, not gasoline one. Its not that
strong. Sorry
-Mike
shame cos they look the business...if rc4wd can make these for this price then similar housings, a bit wider, beefed up and sized for an fg diff with nutech ring and pinion should be quite doable, then there'd be a bunch of diff options available.
i do know someone who could manufacture housings, CVD's and axles (I've already talked with him about the feasibility), but it's all a matter of demand and volume, how many people would really be down for a set (without diff)...if there was enough real interest I can try and persuade my buddy to get a price worked out. Is this something 1/4 scalers would be after too...
maybe I'll start a poll
Hi Julian,
strong. Sorry
-Mike
WA
i couldnt commit to any thing right now but the interest is there... i would be interested in a set of front axle's though..... seeing as to cost...
NY
Sorry if I steered ya in a bad direction with these axles guys.....I was basing this off a few purchases I have made, and they went smoothly. Granted I had not ordered anything that was "special". Kind of sucks those yota axles are shown next to a Baja 1000....a GAS truck. Hopefully something works out, a large scale crawler would certainly be a cool thing to see.
WA
ORIGINAL: Soloratov
