Go Back  RCU Forums > RC Airplanes > RC Gliders, Sailplanes and Slope Soaring
Reload this Page >
Hobie Hawk fuselage painting.
RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Old 07-16-2008, 12:39 PM
todsladek
Default Hobie Hawk fuselage painting.
I'm looking to refinish the fuselage of my Hobie Hawk and can not seem to find a suitable spray can finish. Monokote "Lustercote" is no longer available in the US in orange because of EPA restrictions. Can anyone tell me what spray can finish would work on a Hobie Hawk fuselage. I'm looking for orange. Thanks!
Old 03-31-2009, 09:59 PM
pokypaden
Default RE: Hobie Hawk fuselage painting.
Krylon enamel should work, it can be found at most hardware stores. However I use Velspar auto paint. It can be bought in pint cans but even at that can be costly, as well as you will need a compressor and sprayer.
Old 03-31-2009, 10:24 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Just a thought. When I built mine 30 years ago I used Duplicolor from the auto parts store. If you sand down the fuse you want to run a propane torch over the front plastic part, I don't know why, but it was in the instructions.
Old 04-01-2009, 03:55 AM
snuts
Somewhere I was reading about flashing off plastic, before painting it. I tried to follow it, sounded like a process to bring out some of the petroleum products to the surface, to be removed, to help the paint adhear better.
I may be wrong, hopefully someone else can steer you to the right sorce of this concept. And how important it might be, it may be neglegable. Snuts
Old 04-01-2009, 09:30 AM
2milehiguy
Do a search for the Hobie hawk site and research this. I have done a few Hobie fuses. After sanding you must use a torch on the forward part of the fuse. After that Krylon and the rest work fine. Bob.
