Futaba 9254 @ 6v
My Feedback: (9)
RE: Futaba 9254 @ 6v
I have seen this question come up before. Simple quick answer is, they are rated for 4.8V only for a reason. Go ahead and run it at 6v, but when you crash because the fets in you servo are fried, take a picture for us!
Best deal I have found: www.cheapbatterypacks.com go to custom packs. Make a 4cell pack with some good cells. I got a 3300MAH pack and it was only $24.00. You are better off running it at 4.8V IMHO.
goodluck
Sean
goodluck
Sean
LA
ORIGINAL: ifixairplanes
goodluck
Sean
goodluck
Sean
Mike
My Feedback: (9)
Mike, I am sorry if you mistook my post as being derogatory. No offence was meant to be taken by you. After re-reading your original post I see you are running regulated 5V. That should be fine. A freshly charged 4.8v pack can be as high as 5.55V. and thats OK.
Again sorry if you mistook my post as being negative.
Sean
Sean
LA
Sean
Sean
Mike
TN
I've been using the 9254 and 9253 on regulated 6 volts for over 3 years on the 53's and just about 9 months on the 54's. As long as the voltage is requlated you're fine. Most servo systems are designed to run on 4 drycells which equal 6 volts. Most nicad 5 cell packs will come hot of the charger at 7+ volts and that's why Futaba and JR digitals don't like 5 cells.
TM
TM
