Digitech Jetcat Information Screen Wireless!
My Feedback: (10)
as you might now we where working on more options.
this i want to share with you.
i managed to get the info screen running with XB Pro units without to much hassle.
if there is enough interest we are willing to invest in this.
but for some guys i will explain how to make it yourself:
you need basicly these 3 parts :
2 X XBee PRO 60mW Wire Antenna : http://www.sparkfun.com/commerce/pro...oducts_id=8742
1x XBee Explorer USB : http://www.sparkfun.com/commerce/pro...oducts_id=8687 (xbpro programmer)
the explorer is needed to make your units unique to only communicate between both units , for example you can use the engines or ecu serial to communicate with the unit on ground.
otherwise it is possbile to read also your neigbhours data.
optional is then offocurse you could receive it on multiple units example / laptop for storage and info screen for direct info..
since the data stream comming from the jetcat ecu is compatible with the jetcat software..
XBee 5V/3.3V Adapter Board from : http://www.sparkfun.com/commerce/pro...oducts_id=9132
with these 3 items it is very easy to convert to wireless.
the pro units are illegal in europe but legal in the US.
the range i tested was about 700-900 meters
also you CAN use the XBpro to make a wireless connection between your ECU and your windows based laptop and run the Jetcat software with this wireless system.
for us to use it with the info screen we basicly need a small box to hold the info screen , Lipo 700 mah and a powerconvertor from 7,4 to 5 volts
so if there are guys out there who want to try it and test it let me know if i can help to set it up
for wiring you can have it work within 10 minutes on the laptop and a bit longer for the info screen since you need a power convertor .
but i am looking also getting the power from the TX
My Feedback: (10)
RE: Digitech Jetcat Information Screen Wireless!
ORIGINAL: i3dm
I would love to test one fror you Sandor.
Having a wireless GSU is brilliant ! besides, if the range is 900m, you would be able to see the data on the ground the entire flight ?
testing is done , we are moving to development
yes data is constantly refreshed just like the unit is on board
My Feedback: (10)
ORIGINAL: i3dm
Can i pick up a test unit from you in 2 days at Jetpower ?
ORIGINAL: digitech
Nope sorry only have this test unit for now.
i first want to test the wire versions and the 900 mhz 15 mile!!! version
then i want to see if the chinese can make me a box to hold the lipo screen and power convertor..
