C-ARF Ultra Flash build Thread + Video
#5952
#5955
Be careful at reaching speeds of upper 200s and 300 mph. Lost my first UF this past summer due to right aileron flutter making a full throttle pass from a 1000ft. Right aileron de-laminated and the right wind folded at the fuselage and departed...I fly with a Rhino 36lb thrust. I was very fortunate not to loose everything inside and mostly lost just the airframe.
#5958
If it was de lamination it was before it left the ground or from flutter. Flutter will destroy any structure, in micro seconds.
If the wing/tail is stored incorrectly and the control horn is pushed on (or gear collapse or transport) the foam will tear, the hinge material is very wide, but the lifting will give control slop.
A diving full power UF can pick up speed really quickly, not a good idea, gyros don't always cope with a big speed differential either.
#5962
It's a very rare pass at full throttle it's nearly 200 flights old all my leading edges are taped and fly at those speeds very gently. Most of my flying is taking advantage of the acceleration afforded by the bigger engine.
#5963
What caused the flutter on my UF was the HD Dubro servo arms that were used. The flutter was bad enough to start striping the plastic teeth which caused even more flutter until failure. But this all happened in about 2 seconds or less. The servo was a JR 8411 which was actually still in working order and fine after the flutter and crash. I have new HD Dubro arms on my current UF that replaced the crashed one but don't push this UF as hard. I absolutely deliberately pushed it HARD on the pass that cause the crash. I thought it could go 300+ after watching the youtube vid were the guys went 300+ with a kingtech 210 on their UF. I have some nice SWB metal arms to replace the Dubro arms one day though.
#5964
For some reason the JR dubro arms are a loose fit on the splines, they push on with almost no resistance. I won’t use them on high demand installations. The model was designed for the JR superservo HD arm and these stand up fine.
#5965
I have seen delamination occur only at the flap hinges... that was caused by a high speed full flap deployment. Now full flaps will not deploy above 100mph... Gyro gain is adjusted by speed to avoid oscillation... If built right and properly planned, this jet can be flown over 300 mph easily...
Now the challenge is to time how long I can keep the throttle pegged all the way...😀
David
#5967
1 Post
I was there to see the flight, Omar really pushes his UF. Insane actually. He pushes his models to some serious limits. Its very entertaining to watch. Mabrook my boy.
You should upload your UL video :-)
#5968
My Feedback: (28)
I will never use the Dubro servo arms again. I lost my SM Hawk when the Dubro arm jumped splines on the servo and locked full over. My aggressor flash is using JR 8411 with the JR HD plastic horns. I really like those. My Fly Navy has Futaba 9156 with metal Futaba arms (actually so does the rudder on the aggressor).
#5969
Anyone here ever flown or can compare to a JetLegend (now BVM) Viper Jet? The 1.9m version.
I've been flying one for like 6 years now first with a k100 and then a k140.
I fly from a 400 foot paved runway with death looming on all sides if you run off.
I never push it full throttle except in climbs and its not all that fast at 3/4 throttle. Probably 150 or so.
Im curious what I could expect to be different with a UF and why. My AUW is about 29 lbs.
First things I am wonder are the intakes are much smaller on the UF as is the canopy.
Considering getting the black and white UF as Im tired of the viper, which just happens after 1000 flights.
#5973
Handling wise the UF is smooth and groovy, but the elevator is powerful with less stabiliser to cancel heavy handed inputs.
If you have 1000 flights and you have not broken it, my guess is your thumbs work fine ;-)
#5974
It will be a stock build, Behotec C-36-2 gear, with Jet A1 legs and Intairco wheels, plus JR 8411 and 8421 servos. I'll use a spare P-120SX or 160SX I have.
Will see how free time goes around other projects, but should not take me long!
#5975
Think I have found everything! It's amazing how things get spread around...one elevator servo cover took some serious searching!
