carf mig 15
carf mig 15
Just finished building a carf mig 15..PHEW!!!! How much nose weight does this plane need? It seems like I need more than 1,5kgs. Is something wrong in my plane or is this normal? I am using a p120 engine. EVERYTHING is in front.... any more and it will be out of the nose....
thanks
thanks
RE: carf mig 15
Anurag,
Very normal for this model.. I added over two kilos of lead in the nose ring and with every thing up front, it almost balanced.
FYI there are several long threads on RCU and some others about all the traumas with the CARF-Mig 15. I sold mine before I finished it, but I have been told it's worth all the effort when you get to fly it.
Good Luck!!
John S.
Good Luck!!
John S.
RE: carf mig 15
Yes i would tend to agree about the traumas... But mine is now 99% ready... I will surely fly it... Its a tiresome build...but my god, its the most gorgeous looking airplane...
RE: carf mig 15
Hi Anurag!
Do you use the original tailpipe? You might concider installing a lighter tailpipe from JetCat.
I bought a MiG-15 ready to fly. It was build by my friend Heiko Gärtner from the german jet team and is one of the three kits that were made for the jwm. It has the turbine further forward and with the original tailpipe I still need 1kg lead in the nose. But it flies beautiful. Once I get time, I will change the tailpipe and finish the model, for now, I prefer to fly it
David
David
RE: carf mig 15
I have the original tail pipe from carf. How can I get the new light tail pipe? I also wondered if its possible to move the engine forward... didnt know it was possible due to the wing tubes etc.
My Feedback: (145)
RE: carf mig 15
One thing you can do to lighten the tail pipe is to remove the springs that they use as spacers and cut off 60% of them. THen rebend the hooks and put the spring back on. This saved me about 3oz total in the tail. Every bit helpes back there. I also drilled lightening holes in the motor mount rails. Scotty
RE: carf mig 15
The new 2011/12 Reworked Mig kit will really help make this model a pleasure to build and fly rather than just fly!!
Looking forward to mine coming.
Rgds
Mark
Comp-ARF UK Rep
Rgds
Mark
Comp-ARF UK Rep
RE: carf mig 15
Mark
Can you be more precise about this new kit ?
Do you think it will still be a scale model like the A4 or the other kits of this category ?
Thank you
Jean-Philippe
Thank you
Jean-Philippe
RE: carf mig 15
Its the same super scale detail, updated pre-fab, gear doors etc sorted out, New wing mounting to get the turbine further forward.
The old kit would need major surgery to achieve the same. It has lots of wing and still flys great with the "whole" church roof up front.
Dave
Dave
RE: carf mig 15
ORIGINAL: Ragz
thanks
thanks
Frank
