Jetcat ECU question
My Feedback: (80)
RE: Jetcat ECU question
I can see it moving up and down on the connector pins to the other circuit board, just not sure how far down on the pins it has to be to keep a good connection. I dropped an email to Jetcat. Ill see what they have to say. Any of your ECUs the same way?
My Feedback: (80)
If any one else has this issue there is supposed to be a plastic spacer installed above the circuit board to keep it in place. This one either fell out or was never installed. Sent off to JetCat to have it installed. Luckily found it on the bench and didnt install it in the plane
My Feedback: (28)
I have had several that wiggle around a bit. If it is the whole board, then there is nothing to worry about. I called Bob Wilcox on this years ago. As other have said they usually put a spacer in there to take up the extra room. Bob told me to ignore it (as it wont do any harm) or open it up and put a shim in there. Now if the connector is the only thing moving instead of the whole board, then you have a different issue. I doubt that is the case. Call Bob, he will most likely give you the OK to open it up and see for yourself.
Dom
Dom
My Feedback: (80)
Yeah I sent him an email. He said there is supposed to be the plastic spacer installed from the factory. It either wasn't installed or it fell out. I sent it to him so he could take a look. The board would come nearly all the way off the pins that interconnect the upper and lower boards. Better safe than sorry I figure.
