BVM F-16
BVM F-16
I've bought a BVM F-16. It's built but not finished. Just wondering if anyone has a copy of the photos which go with the instructions ? Any help would be greatly appreciated..
I plan to put a jet Munts vt80 in it. Will post some pics shortly.
FL
RE: BVM F-16
The kit includes full size plans and a comprehensive photo illustrated instruction manual.
We can send you a manual if you need it. Send an e-mail to [email protected] for the price and shipping information.
My Feedback: (57)
RE: BVM F-16
The problem with BVM as well as Yellow is realstate for equipment, or lack thereof, its a tight fit
Have you considered EDF as an option. It is a great kit but the gear really takes a beating at higher wing loading.
My honest opinion, this was a great DF model but converting it to turbine really pushes the envelope.
Think about it, this would make a superb EDF model.
FL
RE: BVM F-16
EDF conversions for the BVM F-16 are a great idea.
About a yearor two ago, I was pestering BV to sell me the completed turbine powered F-16 that he had stored in the backshop. He said he had other plans for it, so one Saturday he and I got it down and we stripped the turbine equipment and inlet out of it to begin the EDF conversion. From start to finish, the EDF conversion basics were completed in a day or two. The conversion is a simple job that the average modeler can complete in a week of evenings.
The P-60 bypass tube and tailpipe ended up in the Bandit ARF Mk II prototype.
The EDF conversion kit includes everything needed to convert a Vio Fan version to BVM 12S EDF.
The "Vio Jet" or "Vio Fan" fan mounts remain in the airframe, and two of the three 4S batteries replace the saddle tanks. A hatch must be cut from the fuselage bottom directly behind the main landing gear mount frame to contain the third 4S battery pack.
A conversion from a turbine powered airframe to a BVM EDF unit will require the installation of a ducted fan inlet trunk and the EDF/Vio Fan mounts.
The 12S EDF conversion really breathed some new life into the F-86.
My Feedback: (13)
RE: BVM F-16
A few pics of my BVM F-16 Dynemax/scorpion 630, 12s (6sX2) 5300, 45-65c.
AUW 16lbs and forgiving on landings if CG in correct location. Even on dead stick.
This air frame is almost the same size as my yellow F-16C (green version). The parts are almost interchangeable with very minor work..
After a some flying time on this configuration, it is going my Wren 54MKIII 14lbs thrust/aprox 7 oz per minute. I have seen a Yellow F-16 fly on a GoldenWest FD3/67 ( also have one) very well. It only produced 8lbs of thrust, has a greater weight and used more fuel..
Steve
Steve
RE: BVM F-16
Steve. I see your elevator servos are in a different spot from mine. Did you modify the position of them?
I like the leading edge mod..
Cheers Andrew
Cheers Andrew
My Feedback: (106)
PA
RE: BVM F-16
Completed BVM F-16 EDF conversion and first flew it with the conversion at the First In Flight Jet Rally in May of this year. Harley Condra worked on the 16 at First In Flight but I'm not sure if he actually saw it fly. Harley is a real gentleman and was very helpful resolving a main wheel problem. BV and many others saw it fly this past weekend at the Mid Summer Afterburner Jet Rally in Hamburg, PA. The BVM EDF conversion is very straightforward. We are using the BVM EVF 2 12s fan unit and the three 4s 65c 6600 mah Thunderpower batteries. We had been flying the F-16 with BVM 91 power. By comparison, the performance with the EVF is vastly improved - especially takeoff and vertical - and we typically fly off grass. Probably have 30 or so flights with EDF power. Not quite turbine level performance with the EVF, but very, very close. And the reliablilty factor now allows you to slow-fly the plane which is very important - although I cant seem to convince my 2 sons to try this - they dont want to waste the amps on slow flight. So much power that you will need to throttle back on some manuevers - like the max turn for example. With the EVF, flight times are 4:30 max. Make sure your landing gear is operating 100% - cycle the gear several times before each flight and refill - you may want to consider adding a gear fail-safe device or at least add an extra air tank for more volume. Also make sure your nose gear has the aluminum moving parts - not the black carbon fiber filled nylon - send it back to BVM for the mod. to aluminum. Also, make sure you have the aluminum nose gear flex arms - not the black plastic. Don't forget the stabilator re-inforcement shown in the manual - this applies to both the turbine and EDF conversions. If you have any questions on the flight characteristics, feel free to call Anthony 610-322-7456 or Steve 610-324-2928 or any questions about the plane itself and the conversion call me (sam) 610-436-5552.
My Feedback: (13)
RE: BVM F-16
Andy,
Sam is spot on about the upgrades to the gear. If you end up grabbing that tank from me and want to get the gear stuff done, just have BVM send the parts to my place and I'll throw everything in one box for the trans-pacific haul
Dave
PS-I'll get that volume to you this weekend
Sam,
What turbine did you have in there? I've got one built and flying electric and another half done for turbine. I know lots of guys have done the P-60, but I think I'd like some more oomf. Think we could cram a P-100 in?
Dave
Sam,
NY
RE: BVM F-16
Im sure the P 100 will fit , I have seen p80s in these airframes so a 100 should be no problem. Your problem will be fuel, I have one with a functional center belly tank and may just drop a p100 in it.Its going to get small real fast! I saw sams fly at Hamburg this past weekend and it was looking good.
RE: BVM F-16
Did a little bit more on the F-16 last night.. Found one of the aileron was warped. Luckily I was able to straighten it by splitting the trailing edge and apply some heat.. Just have to reglass and its good as new..
My Feedback: (13)
RE: BVM F-16
I was thinking the 100 would have to be turned down a bit. I've got the BV conversion kit, but can't remember how much fuel that is...I was hoping it would be enough for a turned down 100. I can't see using much more than a P-60 except for T/O, go arounds and hi-alpha flying. Anyone have any ideas here?
I guess part of me doesn't want to buy an old motor that is pretty small when I could buy the newest/latest/greatest for just a bit more money, and very little excess weight (maybe even up weight-wise when you consider all the valves, etc) that would provide me options for bigger airframes in the future.
Dave
Dave
My Feedback: (73)
RE: BVM F-16
ORIGINAL: Jetkopter
Hey Don, did you ever get to fly that F-16 on the P80? The F-16s flew well on ram 500, and i was curious how it would have flown with the fully bypassed p-80. The original glo powered ones flew ok as well.. Lots of runway needed
The p100 would fit perfectly, but there is not much room for fuel. The wet center-line tank might be more of a necessity rather than option depending on power plant selection and power rating.
~V~
My Feedback: (13)
RE: BVM F-16
Well guys, here's an update to al old thread.
I ended up doing the conversion from EDF to turbine on my old F-16. I originally had an EvoJet Booster 90 in it (first 6-9 flights). It was a borrowed motor, so I pulled it out (worked great tho, easy install, quick response, etc), but I was getting nervous with it being borrowed, so I replaced it with a Wren 54SS. About the only change between the two is that the Wren is about 2oz lighter, but is propane while the Evo is kero start.
I am quite happy to have the extra thrust, especially at our density altitude. I am just starting to get comfortable slowing the jet down and working it down. I'm getting to the point where I can fly it around with full aft stick and ~3/4 power and the rudder. Impressive to see if I get it right. The plane doesn't drop a wing, the sink rate just goes through the roof if you don't keep a hand in the power.
I get about six minutes from either of the engines and the stock BVM fuel tank arrangement.
I've found the gyro called for in the conversion kit to be mostly useless.
I hope this helps guys
Dave
Dave
NY
RE: BVM F-16
Wojy, I put a p 100 in it , I get six minutes on the main tanks with no reserve and an additional 4 minutes with the belly tank installed. I never did fly it on the P-80 . I dragged it out of the basement last month and went through the whole plane. The small size of the Version 10 ECU makes the turbine install alot better. Next nice day at Hamburg im going to give it a try .
RE: BVM F-16
Well its been a while since my last post.. I've dragged the F-16 back out and started working on it.. I now have another kit and also another complete flyable F-16 in ducted fan setup.. This gives me a total of three BVM F-16's..
The grey one which is in the pics is now going down a different road.. I picked up a brand new BVM 10s setup which I'm going to install in it.. Last night I began installing the ventral fins and modified the original ducting to fit the evf setup.. Just wondering if anyone has any experience with this fan setup?? And where I can buy batteries for it from at a reasonable price??
Bumping an old thread - maybe there is a more recent one, but with 3 different versions of BVM F-16s everything more recent I could find pertained to the 1/6th and 1/5th models.
Anyways, anyone have any tips on disassembling the main gear to either add a spacer or at least replace the spring? Working on one now and it basically bottoms out the main struts when sitting on the gear, springs are super soft or worn out I imagine. I haven't weighed the airplane but it's no pig. This one was originally converted and flew on a P-80 with the centerline tank, I've got a Jets Munt 70 in this one so it will actually be on the light side as far as a turbine conversion go, though I have not yet weighed it.
Is 7.5-8" from the wing leading edge/fuselage break about right from what I've found?
The springs are ok! They sit on block on the ground, that is then stabil for crosswind and so on.
Mine is only 6,2kg and nearly to light for the original bvm springs.
My cg is 150mm.
Still my favorit plane...
Good luck and fun with yours!
regards Martin
Thanks for the reply Martin - I haven't gotten this one on a scale just yet, but I suspect it will be a bit heavier than yours. If they are springs, they can certainly wear out just like any other spring. This main gear will compress 100% with just a slight load and will not unload without lifting the tail by hand.
When you say 150mm, I presume you are measuring straight back from the leading edge of the wing? If my eyes were right when I checked that yesterday it looked to be about 8.5" (215mm) down the leading edge, so just a bit behind the 8" BVM suggests.
Yes straight!
They are soft. On the ground and at the start they are always compressed. They do minimal damping when you land, also because of the lead of the wheels, i think.
regards Martin
regards Martin
