NEW YT PANTERA JET BUILD THREAD
#55
I have flown these with P80's and the Wren 100 I have not found it necessary to use anything more than the heat reflective tape to shield the fuselage where the turbine exhaust exits. However I did find the Wren 100 before I had the defuser fitted did make the surface warm.
#59
I'm sorry,
No testing of the Pantera. Yesterday afternoon I was at the camp two hours waiting for a strong wind... Test and movie postponed to Friday I guess ... I will keep you updated.
#61
Here my pantera's maiden fly http://youtu.be/LGTwqfQn27U
How did you find the CG and flight performance?
Cheers
#63
Fortunately my Pantera had only left wing destroyed but thanks to Italian reseller of YT International , 8fly , after just 3 days I got a new pair of wings No other damage Fortunately
#64
Banned
Judging by the take off speed and length needed and indeed the fast landing do you not think the plane was nose heavy. There has been so much debate about the C of G on this model. They will actually land very slowly indeed
#65
Finally! Yesterday first fly of my Pantera Jet.
Perfect except for the brakes that were blocking the wheels too soon. In the two movies that post in youtube see the brake block immediatly the well. No problem... Confirm that the exact CG is 4 cm forward at the rear edge of the canopy, measured with down landing gear , full UAT and empty tank.
For the rest all fantastic: the model has necessitated in the first flight of the usual trimming of the three different phases of flight, but nothing special. The turbine, needs other 2° negative for be perfect.
The turbine P100RX I think is ideal for this model and drives well. In the second video we can see how the model fails to take-off climb easily with the Pantera Jet weight 11kg to takeoff.
Yesterday I see that the model with all flap moved wings but I must check today and tomorrow in the next flights if it was because of the light crosswind.
The Panther performs well in flight and is able to combine low speeds with hight speed. The landings with flaps extended (I have 8cm excursion to the flaps) are not really a problem. I think you could squeeze a bit 'more of the spring nose gear that take-off seems to be a little' soft.
I remember my Pantera has all the standard equipment of the kit (gear, legs struts and brake by YT).
The video is loading and will soon be available on youtube at
http://youtu.be/hrXeNp8Yxk0
#66
I think you may be right, the problem may also be the fuel tank full (2.5 litres) which is located in front of the cg. However today I retry using 80 mm down flaps (on maiden was only 40 mm)
#67
Hello,
this weekend I was able to fly with my Pantera Jet and I must say that fly very well. It 'a model that makes her look good in the airfield. Funny. If have some question send me...
#69
She will slow up a lot more for some really slow landings, just use 80 degrees + of flap.
Just back from Jetpower where the Pantera went really well, hold her on the brakes at full power for a really short take off, looks spectacular
#71
i am about to order one on the 1st of november its killing me waiting for payday . i plan on building the jet over the 4 weeks adding good quality servos then ile buy myself a brand new turbine the following month ' IM SO EXCITED i dont live far from birmingham so i might go there to buy it personaly , but knowing those hurricanes are in the back its best not to go or ile spend all my money !!
#72
Mine had its maiden flight on the weekend. Lucky enough at a full size airstrip for the test flights
Initially the CG was too far forward, but some minor adjustment and all was well overall and it flys very well. Smooth and stable.
KingTech K80F for power, 11.5KG dry weight. 2.5L Fuel tank.
