Reload this Page >
BVM soon to release a new F16 PNP
Old 09-21-2014, 03:39 PM
  #276
jfetter
Originally Posted by gunradd
Nice video Jack and great flying Rob!
Thanks Gun! I was impressed with how well the lights show up in the evening, on video even ;-)
Jack
Old 09-21-2014, 05:43 PM
  #277
kevinthoele
Did not read the whole thread but got the opportunity to fly the BVM PNP 16. Added 2 ounces of lead to the nose and it made a world of difference in landing. Did not effect the trim at all during flight. Also used a reduced elevator rate except for take off with full smoke fluid on board. Full rate elevator for take off with smoke otherwise middle rate elevator was perfect for entire flight.
This one is a real winner
Old 09-22-2014, 10:50 AM
  #278
gunradd
My Feedback: (9)
gunradd's Avatar
Got time to start working on the cockpit details. Keep in mind I get carried away with scale stuff so the stock cockpit is probably ok for most people.
The ejection seat is a poor excuse for crap on this plane and needs major mods to look decent. First it needs to be much taller. So cut it and raised it. I also had to remove the oxygen bottle but will detail that and reinstall it later. Then I used some BVM poly ply to fill the gaps. from raising the seat.
The seat belts are tiny and not even close to getting around a pilot so I removed them and will try and make new ones later.
The Acces II ejection seat has pitot tubes on the top and the ones that come on this plane are installed backwards on all the F16s I have seen . Highly recommend changing them at least.
I added some metal tape so I could make more details on the seat and cut up some thin rag material to use the the top and upper sides of the seat.
ID:	2034221   Click image for larger version
ID:	2034222   Click image for larger version
Old 09-22-2014, 10:52 AM
  #279
gunradd
My Feedback: (9)
gunradd's Avatar
I also decided to add some of the details on the glare shield.
ID:	2034225   Click image for larger version
Old 09-22-2014, 10:54 AM
  #280
gunradd
My Feedback: (9)
gunradd's Avatar
Tomorrow I will start working on fixing the oxygen bottle and adding the lines to the side of the seat along with the flight data recorder and make some decals for the seat. Such a nice plane deserves a decent cockpit not a cartoon cockpit.
Old 09-23-2014, 12:21 PM
  #281
smaze17
My Feedback: (60)
Hey Gun, would you consider doing these cockpits for other people for a fee?
Old 09-24-2014, 01:53 AM
  #282
gunradd
My Feedback: (9)
gunradd's Avatar
Probably not. Its to much work lol. I hope to motivate others to do it themselves. Did a little work. Will post some pics of it later.
Here is a pic David Hart got at the event a few weeks ago of the F16. With the new springs it has a much better ride and scale stance.
Old 09-24-2014, 02:51 AM
  #283
Countryboy
My Feedback: (25)
Countryboy's Avatar
Kris, I thought that may be your response. I agree, these one off cockpit upgrades do consume a lot of time. On the other hand, it is a very rewarding/fun experience and I would encourage anyone to give it a go. Link to my cockpit upgrade for my Eurosport.... http://www.rcuniverse.com/forum/rc-j...it-detail.html Another link on making scale instruments... http://www.rcuniverse.com/forum/rc-j...ml#post9978441
Kris, the F-16 looks great.
Ronnie
Old 09-26-2014, 05:19 PM
  #284
gunradd
My Feedback: (9)
gunradd's Avatar
Thanks Ronnie!
I am almost done now just need to build up the rear cockpit where the canopy actuator and other things go and add some decals to the seat. Also need to paint the stupid red dot on the HUD. You never use red on an aircraft that has NVGs. Its 100% the opposite of the correct color and needs to be changed.
I finished making the ejection seat taller. I made new seat belts for the seat that go around the pilot. Installed the ejection seat pitot tubes the correct direction. Also did lots of little details that no one will probably ever see lol but they are their. Very happy the way it came out. Gives you a reason to get close and check out the details. Also added the flight data recorder to the ejection seat.
The stock ejection seat rails are not very scale and pretty thin and will warp in the heat. I removed them and made new ones that look allot better.
ID:	2035293   Click image for larger version
ID:	2035294   Click image for larger version
Old 09-26-2014, 05:50 PM
  #285
smchale
My Feedback: (67)
smchale's Avatar
Already looks way better Kris, nice!
I'd slide the pilot down just a little and lean him fwd. I believe they are only reclined when pulling high G's.
see attached of where I ended up with my pilot.
btw, good call on repainting the Target "easy button".
Old 10-01-2014, 09:45 AM
  #286
P. Richards
P. Richards's Avatar
When Kris fly's it's a lot of High G's, nice job man, I am seriously considering pulling the trigger on the F-16...
P. Richards aka SwatTeam
Old 10-01-2014, 04:17 PM
  #287
smchale
My Feedback: (67)
smchale's Avatar
Do it P! We'll pass your camera to someone else next year and all fly together!
Old 10-01-2014, 04:53 PM
  #288
gunradd
My Feedback: (9)
gunradd's Avatar
Thnx P!
I hope you bring one to Kentucky next year! 3 F16s in formation would look good
I got the cockpit done today. Will post some pics soon. BTW thnx Sean for showing me the seat was still a little low............ 2 days of work later the seat is raised another half inch and looks good lol. Couldn't you just say hes a tall pilot??
Old 10-04-2014, 05:18 PM
  #289
gunradd
My Feedback: (9)
gunradd's Avatar
I decided the plane still Sat to nose high and not scale enough looking so I took some of the spring rate out of the nose gear. That along with raising the mains make it sit almost level.
Old 10-04-2014, 05:23 PM
  #290
gunradd
My Feedback: (9)
gunradd's Avatar
For the angle of attack probes They come way to big. So Sean suggested drilling a hole in the radome and installing them from behind. I needed to add a few washers to pull them in further and now they look great.
Old 10-04-2014, 05:52 PM
  #291
smaze17
My Feedback: (60)
Lookin' real good Gun!!
Old 10-04-2014, 06:20 PM
  #292
smchale
My Feedback: (67)
smchale's Avatar
Looking really good Kris. Amazing how such little changes can make a world of difference. Most people won't notice, but those that do really do! Next mod is to angle the tip rails down a few degrees. Remind me, I'll text you a photo of how I did mine. Another simple adjustment.
Ive been fielding a lot of emails about this model and people are really still excited about it. I love the reaction when you let them pick it up! Lol.
Old 10-05-2014, 09:09 AM
  #293
bluescoobydoo
I think you will find you want the high a of a on take off to stop it leaping at rotation and the nose will level out under take off power, at least mine does
Old 12-07-2014, 01:57 PM
  #294
gunradd
My Feedback: (9)
gunradd's Avatar
A little video from an event over the weekend. Loving this plane more and more. The high alpha passes are the best. I do one toward the end of the video. This field has a very tight flying area so its banking and yanking mostly.
Enjoy.
https://www.youtube.com/watch?v=9g1Z...ature=youtu.be
Old 12-07-2014, 03:59 PM
  #295
P. Richards
Nice flying and great landing...
Old 12-07-2014, 05:32 PM
  #296
ddavis72
Here is my new Ace in the Hole scheme BVM F16. Purchased this summer, got it in October, maidened with Nick Johnson as test pilot Dec 2. It's really something. Kingtech 140 powered. It is my first turbine. Progressing up from an Electra and many years of just general RC experience. 3 flights, I got one TO/LDG cycle. If you consider what we do is to move the sticks to make the airplane sound and appear a certain way (learned from experience), then turbine flying is very different than what I have done. The appearance, sound, response of the airplane... all different. But I am very confident in this airplane. Nick demonstrated that you can barely force it to stall, and I performed less than perfect TO's and landings and the airplane did not bite. It does not seem to have dark corners. I cannot wait to get more time on it.
Old 12-07-2014, 07:17 PM
  #297
Jeremy_D
Jeremy_D's Avatar
That's a great looking scheme!!
Old 12-17-2014, 07:58 PM
  #298
ddavis72
Hello guys. I had a recent issue with my F16 I thought I would share so you all can keep a lookout for it. On my 4th flight nose gear failed to deploy and had to land on mains, taking out the nose door/ cylinder/ hinges. About a $150 crash, small dings and couple nights repair work. Inspecting afterwards, it appears that the unlocking cylinder (which does a complex twist as it cycles) locked up just on the edge of the main nose gear strut. This locking cylinder is anchored to the CF crossmember with an aluminum block and 2 bolts. At first I thought one of the bolts might have sheared or come out, allowing that block to rotate just slightly enough to cause the mechanism to bind with the main strut. On further takedown of the assembly, however, the 2 bolts are fine. The holes in the CF crossmember appear to be drilled with enough slop in them to allow the aluminum block to rotate. I don't know if this is just mine or if it could be present in other nose gears also. Short of retapping the block for larger bolts I am not sure of a way to completely stabilize this. I intend to dremel off just a bit of the main strut to allow clearance should this happen again (and also cycle my gear before each go out). Pretty disappointed in this small failure. Paid a lot of $$ for this stuff to work flawlessly. Tried to post a pic but RCU is not cooperating. I can try again if anyone is interested.
Old 12-18-2014, 08:36 PM
  #299
ddavis72
Does anyone have a nose gear door front hinge that they would care to sell/ loan? BVM is on backorder for now on them. By "loan" I mean you could send me yours and then I could replace it when I am able to get a new set from BVM. We could use paypal or other means...
Old 12-19-2014, 01:21 AM
  #300
jeff sewell
I have some if you're desperate as I'm in the UK.
Jeff
