Reload this Page >
JR 28x information
JR 28x information
Old 03-24-2015, 03:40 PM
  #151
jetpilot
My Feedback: (48)
jetpilot's Avatar
ok, have most of what i need programmed but i noticed my receiver was operating at 120 degrees. Is this normal?
Just the JR RG 031BX was hot. everything else cool.
Name:	2015-03-24 18.30.23.jpg
Old 03-24-2015, 04:13 PM
  #152
warbird_1
My Feedback: (61)
warbird_1's Avatar
i noticed that my receiver is a bit warm too. i was thinking that it was from the really bright LED's
Old 03-24-2015, 05:31 PM
  #153
drac1
drac1's Avatar
Originally Posted by jcterrettaz
What store ?
this is a very good price
LHS in Aus.
Old 03-24-2015, 06:35 PM
  #154
jcterrettaz
jcterrettaz's Avatar
LHS : local hobby store? did you have a tel# or a link?
Old 03-24-2015, 07:02 PM
  #155
drac1
drac1's Avatar
LHS won't sell international.
Australian distributor is Model Flight. RRP $2999.00. (I get a slight sponsor discount from LHS). I'm not sure if they will sell international, they may refer you to a distributor in your country as some distributors do, (for e.g. Horizon and not sure about JR Americas), but you can check. Only M2 in stock at the moment. By the time you add freight/insurance, it might not be much cheaper?
http://www.modelflight.com.au/?gclid...FeZbpgodsx8AHQ
Old 03-24-2015, 07:08 PM
  #156
jcterrettaz
Thank you. I check and the radio M2 is not in stock. M2 I presume is mode 2 who is fine for me.
Funny because the radio is more expensive in the US , maybe because of the high US currency @ the moment.
Old 03-24-2015, 07:26 PM
  #157
drac1
drac1's Avatar
Yes mode 2. It does show in stock.
If I bought one from the US at $2700 USD, it would be around $3460 AUD.
Old 03-24-2015, 07:35 PM
  #158
jcterrettaz
I just order one for 1673 Euros , from Belgium. Receiver is the RG 731 Xbus RX . Maybe the reason is cheaper. Good deal and very happy .
From them http://www.ercmarket.com
Old 03-24-2015, 07:41 PM
  #159
drac1
drac1's Avatar
Around $2320 AUD. Mine came with the RG712BX Rx. Xbus and PWM compatible.
Old 03-25-2015, 12:08 AM
  #160
Dave Wilshere
They are all mode changeable and you don't even have to take the back off...
I changed some of my stock to M1 for customers.
Old 03-25-2015, 02:17 AM
  #161
jcterrettaz
Was to good to be true : not in stock. Patience ..Dave you right , I was wondering because you can do all mode with the XG14
Old 03-25-2015, 02:31 AM
  #162
Dave Wilshere
Its only the manual throttle trim radios that are fixed mode.
Old 03-25-2015, 07:21 AM
  #163
jetpilot
My Feedback: (48)
jetpilot's Avatar
so noone is commenting on the 128 degree receiver?
Scott
Old 03-25-2015, 07:32 AM
  #164
kirkj
My Feedback: (61)
Scott
It is normal. There was a thread running on it a while back, and has been discussed at a team level with JR Americas. even brand X tend to run about 130 ish.
Old 03-25-2015, 07:45 AM
  #165
jetpilot
My Feedback: (48)
jetpilot's Avatar
I was speaking with a buddy about this and isnt heat a result of power? this has to be using power to put out this heat.
Scott
Old 03-25-2015, 07:46 AM
  #166
warbird_1
My Feedback: (61)
warbird_1's Avatar
Scott
huu?
Old 03-25-2015, 07:52 AM
  #167
jcterrettaz
all my DMSS receiver are hot , never mesure temperature , but this is normal
Old 03-25-2015, 08:36 AM
  #168
warbird_1
My Feedback: (61)
warbird_1's Avatar
mine get warm but not hot. i think"like i said before" that's it's mostly from the very bright LED's
Old 03-25-2015, 08:42 AM
  #169
Ace913
My Feedback: (104)
COL J
Yes, it's awesome that they incorporated the wireless. Setting the the default link in the browser was a nice touch as well. It'll be a snap to update when they start releasing updates.
Jeff
Old 03-25-2015, 08:54 AM
  #170
Ace913
My Feedback: (104)
Jetpilot,
Can you post a little more of your setup? What XBus components are you using etc? Are you using some kind of battery backer (Powerbox, JR XBus Dualport, Smart Fly etc.) or is all the current for the servos being sourced through the receiver? I'm not seeing those kinds of temps in either the 031BX or the 712 BX. If the receiver is in a relatively cool place in the fuse, I'd say alot of current must be getting sourced to the servos through the receiver to get to those temps. Ideally, you'd not want to source any current to the servos through the 031BX. The current drain on the receiver should ideally be signal related only.. not power and definitely not enough to heat it up that much.
Jeff
Old 03-25-2015, 09:16 AM
  #171
jetpilot
My Feedback: (48)
jetpilot's Avatar
the only thing hot is the RG031BX. everything else is cool.
Name:	2015-03-25 12.14.48.jpg
Old 03-25-2015, 09:27 AM
  #172
Ace913
My Feedback: (104)
JetPilot,
Scratch my last post, I can see from your photo that it's not sourcing current directly to the servos. I just set mine up on the bench with a 031BX, connected to a Powerbox Champion SRS... nothing else connected and no airflow. I saw temps up to 119°F after about 5 minutes. The 031BX receiver and satellites alone draw between 200 and 400 milliamps at 6.5 volts. I guess the temps are normal. However, with minimal airflow around the receiver (small fan on low), the temps dropped to around 100°.
Jeff
Old 03-25-2015, 09:33 AM
  #173
stoneenforcer
My Feedback: (23)
wow pretty sweet radio. im still using my 11x and don't plan to change out all my rx's for this. I think its best to wait a while, this 28x reminds me of the first cell phones, BIG bulky tech. looks like refinements or an affordable version would follow. same as they've done on previous radios..
kudos to whomever gets this one.. very nice.
Old 03-25-2015, 09:35 AM
  #174
FalconD
My Feedback: (190)
FalconD's Avatar
All you guys getting the latest JR, any of you wanting to sell what you are replacing? I need to upgrade, fly a lot of warbirds. Would love some of the features newer radios have. Scale flap speeds and such. Emai [email protected] check my ratings I'm a legit buyer. Looking for excellent JR. radio and reciever(s)
Old 03-25-2015, 09:39 AM
  #175
Ace913
My Feedback: (104)
.... having said that, they're not temps to have any concern about. I would imagine JR has these rated up to 60°C to 70°C. Just a guess but that's pretty common for most electronic components designed to perform in atmospheric ambient temps.
Jeff
