Reload this Page >
FB 1/7th F15 scale build
Old 11-15-2015, 06:32 PM
  #126
bri6672
bri6672's Avatar
I would send the whole thing to dirk if you haven't already done so! I would have guessed your setup should have been sound.
Old 11-15-2015, 06:47 PM
  #127
Randy M.
My Feedback: (38)
Low rpm is a dead giveaway for no fuel. I'm still betting air bubble. Seen my share . Especially on a maiden. I ha two in a row on an L-39. Yeah diesel will smoke on shutdown but not enough to see in the air. My most recent looked like I had the smoke on. Was an rpm sensor that gave up. If the ecu commanded shut down,; no vapor trail. Flame out due to air bubble, fire goes out, pump still goes for a couple seconds until ecu sees rpm drop. Fuel in hot motor make vapor trail.
Old 11-15-2015, 08:03 PM
  #128
mr_matt
My Feedback: (10)
mr_matt's Avatar
Sorry but what kind of shutdown is supposed to be remedied by high flow setup....low rpm from undershoot caused by the pump?.... and what constitute a high flow setup for that matter?
Old 11-15-2015, 08:35 PM
  #129
George
My Feedback: (57)
Matt,
I think Kris is reacting to the high PW of 1000. That is extremely high and "usually" indicates a restriction of some kind, but since he says he didn't find anything in the fuel system, who knows...But something caused the PW to be abnormal.
Old 11-15-2015, 09:10 PM
  #130
David Jackson
My Feedback: (15)
Chris,
Sorry to hear about the crash, glad to know that it is fixable. Look forward watching you fly it in 2016.
Dave
Old 11-16-2015, 04:26 AM
  #131
Randy M.
My Feedback: (38)
My 210 reached pump limit after I installed in my f18. Not sure how his reached 1000.
Old 11-16-2015, 04:47 AM
  #132
gunradd
My Feedback: (9)
gunradd's Avatar
Im not sure either Randy. I was very surprised when I saw it.
Matt pretty much like George said I am addressing the high PW. Eventually I plan on putting the K300 in this plane and I will need high flow anyway so might as well eliminate that part. I doubt my install caused the high PW but almost all flame outs that I have seen are caused by airframe fuel problems not the engine. When I help people trouble shoot flameouts they get pissed at me when I say its in the fuel system but more times then not I end up being right. So I need to at least follow my own advise lol.
When I do figure it out I will post what it was. Will be doing extensive ground testing before the next flight. I am thinking about 2 or 3 weeks from now.
Old 11-16-2015, 04:57 AM
  #133
Randy M.
My Feedback: (38)
I hope you get it sorted out. Very nice plane . Makes me want one.
Old 11-16-2015, 07:01 AM
  #134
gunradd
My Feedback: (9)
gunradd's Avatar
Just wanted to post the takeoff video my son did with the F15 full of fuel and how it rotated. Some have said this plane wont rotate with the stock tanks and full fuel well this is proof. Also after draining the tanks I still had fuel center tank and half full saddle tanks. Probably looking at about a 15 min flight time on this plane with a 210 lol. Keeping this way because the K300 will need it.
https://www.youtube.com/watch?v=mJyH...ature=youtu.be
Old 11-16-2015, 11:25 AM
  #135
gunradd
My Feedback: (9)
gunradd's Avatar
Repairs going fast!
ID:	2130955   Click image for larger version
Old 11-16-2015, 11:54 AM
  #136
ww2birds
My Feedback: (14)
ww2birds's Avatar
You are an amazing example of what a true modeler is: someone who is creative, a true craftsman, and as this work shows, 100% resilient to the inevitable setbacks our hobby can offer from time to time .. Bravo!
Dave
Old 11-16-2015, 12:24 PM
  #137
mr_matt
My Feedback: (10)
mr_matt's Avatar
Not to belabor it but I am still missing something. I get the high PW. I assume that means an unusually high pump voltage at full power.
Did the turbine quit at high throttle or did it quit when decelerating and the RPM undershot?
Or was it a typical white smoke, "air bubble in the fuel line" flame out?
Old 11-16-2015, 01:04 PM
  #138
braza
My Feedback: (17)
braza's Avatar
sorry about your plane man. hope you get bacj in the soon. I test flew mine last Saturday and mine also rotated very easy and track so well taking off. No bad habits at all. Mine is set up with 2 k140 and I had main tank and saddle tanks full and never jumped off the ground on take off. What a great flying plane! CG at 230 mm with uat's full and 1/4 fuel in main tank for balancing.
Old 11-16-2015, 01:08 PM
  #139
braza
My Feedback: (17)
braza's Avatar
Couple of pics...
ID:	2130959   Click image for larger version
Old 11-16-2015, 01:23 PM
  #140
ww2birds
My Feedback: (14)
ww2birds's Avatar
Congrats Marcio!
Can you send a pic of the elevator leading edge so we can see where neutral sits once trimmed out? .. would be a help for those of us who have not flown yet..
many thanks!
Dave
Old 11-16-2015, 02:02 PM
  #141
braza
My Feedback: (17)
braza's Avatar
sure thing. i'll send when i get home tonight.
Old 11-16-2015, 02:10 PM
  #142
kevinthoele
I have seen several flame outs that were the result of collapsed UAT's or fuel lines because the draw was that hard on the line. That will create high PW and match symptoms you are saying. I am flying the exact plane and engine. I used hard 6 mm tubing and Tom Cooks aluminum UAT with big fittings. It is running perfectly
Glad you are making repairs. Best of luck with the remaiden
Old 11-16-2015, 07:06 PM
  #143
braza
My Feedback: (17)
braza's Avatar
Originally Posted by ww2birds
Congrats Marcio!
many thanks!
Dave
Here it's Dave. I took Chris advice and started at center. Plane was climbing a little and i ended up with 8 clicks of down elevator. Chris was pretty close. Trailing edge just a little down from center now.
ID:	2131000   Click image for larger version
Old 11-16-2015, 08:39 PM
  #144
ww2birds
My Feedback: (14)
ww2birds's Avatar
Super! thank you!
Dave
Old 11-17-2015, 03:52 AM
  #145
gunradd
My Feedback: (9)
gunradd's Avatar
Dave
Dave thanks for the compliment.
Marcio congrats of the flight!!
Also mine needed some nose down trim also.
Old 11-17-2015, 04:03 AM
  #146
gunradd
My Feedback: (9)
gunradd's Avatar
Matt you are correct PW is pump voltage and can be the best indicator that your fuel system is working correctly. The engine didnt shut down from the high PW though and shut down due to low RPM. But the PW was higher then I have ever seen for some reason. I would think its also possible I might have a weak fuel solenoid that under allot of power didnt stay open. In my opinion that would give me the exact problem I have but going to rule out the fuel system first.
Causes for low RPM are air bubbles fuel restriction or bad RPM sensor.
I was doing a low slow pass then at the end of the runway slammed full throttle and got the white smoke. Dont know what caused it yet. Will do further testing when I have it all back together hopefully later this week or next week. Late next week I plan on flying it again as long as it goes back together ok.
LowRP
Old 11-17-2015, 11:02 AM
  #147
gunradd
My Feedback: (9)
gunradd's Avatar
Making progress. One of the hard to repair areas was going to be the nose bulkhead where it mounts to fuselage because the bolts pulled through and delaminated the plywood. So cut out the bad sections and made new ones. Then added a bigger piece behind the new pieces that the bolt will go through. Also been sanding and sanding soooo much fun.
ID:	2131106   Click image for larger version
Old 11-18-2015, 03:55 AM
  #148
P51Joe
Marcio i too am running 2 K 140 in mine and I want to know how yours did as fare as performance. mine is not complete yet so I just wanted to know.
thanks Joe
Old 11-18-2015, 01:27 PM
  #149
braza
My Feedback: (17)
braza's Avatar
Joe, engines are running perfect so far. I have 2 separate fuel systems. Rpm is very, very close between the two at idle and full power.
Old 11-18-2015, 04:11 PM
  #150
gunradd
My Feedback: (9)
gunradd's Avatar
More progress! Wings are fixed and now hitting it hard on the fuselage. High flow stuff should be here on Friday so I can replumb it. If all goes well engine runs early next week and flight on turkey weekend.
ID:	2131304   Click image for larger version
