Damiano F86 1:4
Damiano F86 1:4
Hi everyone,
this is my new 1:4 F86.
The model was designed by me, all parts are laser cut ad fit perfectly one each other.
Covered with 2mm balsa and 110g/mq fiberglass.
Engine is behotec 220 reduced at 115000 rpm. About 180 N
It is all in wood fuselage, wings, elevator and rudder. It’s about 18 kg without fuel (3.7liters).
As I do, the model was not yet painted for the first flight.
It’s a new model, new airfoil not copy of flying model airfoil, center of gravity was to verified, servo movements has to be checked…A lot of doubt. Target of the first flight was only to land without damages.
Arrived at airfield, in 5 minutes, the model is ready to fly but the springs of the rear gears has low stiffness. I try to run on asphalt and the it moves left and right but when the speed increase it run like on a binary.
I rotate and the model is in the air. In “take off” flight mode at about 30% of trust I put 5 point of trim to pitch and the model fly perfect. No trim on aileron. “Landing” flight mode require 9 point of trim and no aileron trim.
Target of first flight is to land without damage, I have 3-4 minutes to learn how land. First time was enough. It land much better than my best dreams, very easy and smooth.
In the second of 5 flight that I did I retract gears and flaps and…surprise: no trims needed. This is the first time for me, in 20 years of turbine flight. Target of this flight was set trim, movements of servos and try to understand how it stall. Reduced speed ,flaps, gears. The speed is very low but no stall appear. I will try next time.
Official cameraman of our group filmed the third flight, here you can see it:
https://www.facebook.com/Diavolo.Ros...4178898085008/
The other 2 flight of the day was much better than the third, I’m really satisfied!
I want to thank all persons who help me during this job:
First my dad: he is the person who built the model. When the cut parts arrived he call me: ”please, print the drawings, I can start assembling structure” . The same evening I give the drawings to my dad and he answer me: “too late, yet assembled!” He made a beautiful job! No one trim was moved, Thank you Gianni!
Mirce set, for perfect(and fast) laser cut job.
Alewings, for professional cable set and electronic power system, simple to use, absolutely reliable and not too expensive.
Electron retracts: for the quality of product and for fast customer care. I ask them stronger spring for rear legs, they send me 2 couple of springs for free in one day.
Osvy model, for perfect exhaust tube. Very strong and light.
I’m sorry for my bad English.
Damiano, Italy
Damiano, Italy
Thoemse (04-12-2022)
With great pleasure to announce the start of sales F 86 Sabre - 1/4 scale wooden short kit.
More info on:
http://www.nsmodelers.rs/home/damiano-f-86-sabre
Best regards
Mirce
More info on:
Best regards
Mirce
For "Mirce model" 1/4 scale F 86 Sabre we offer parts for two piece fuselage.
Originally fuselage is from one piece, but for easier transport now it can be separate on two parts.
http://www.nsmodelers.rs/…/…/f-86-parts-for-2-piece-fuselage
Sabre in action...
This year on Top Gun "Mirce model" will have market place and offer wooden kits and Finish & Detail sets.
You can order F 86 wooden kit with 10% discount an pick it up on Top Gun.
Offer valid until April 21.
Don't forget, with 10% discount you haven't shipping cost also!!!
More info on web site and on e-mail.
Best regards
Mirce
Sabre in action...
Best regards
Mirce
My Feedback: (30)
Estimate on airframe with gear
- 550 for short kit with tubs, split frame
- 150 for pipe (the ones the Russians sell are pretty good)
- 1000 for electric gear, wheels, retracts
- 300 for balsa wood, glass, epoxy?
Even at 3000 with pipe and gear finished to a moderate looking paint job its looks like it would be worth a try for many people
What do you guys think the time would be for someone who has many years of experience from start to finish paint on airframe?
I wish there was a smaller version of this, 90 inches or so, it would be worth buying two of them for a lot of people
thx in advance
thx in advance
thx in advance
thx in advance
Damo
