Relationship between gyro and exponentials
What is the relationship between using gyro and using exponential in a model? Shall you avoid using exponential when you are using a gyro or doesn’t it matter? Shall you use less exponential or less deflection instead? In the manuals for the gyros I use, Jeti Assist and Powerbox, there is no mentioning of how to manage exponential. Hope you understand my question.
Jannica
Sweden
Jannica
Sweden
Normally expo on a gyro will make the aircraft very mushy and slow responding. on your gyro ON/OFF switch id program normal expo on the gyro off position, then with gyro on drop expo down to about 5%. The gyro will normally do all the work depending on the brand. Throws will stay the same..
This is what i do and it works well...
My Feedback: (25)
I agree with others, while I use expo I’m cautious with it. Most of the time I will reduce throw on the surface before adjusting expo. That being said My only gyro experience is with the cortez, I usually go for 50% less on the gyro.
IE if I normally use 30% expo, I’ll reduce it to 15% with the gyro on.
My Feedback: (7)
With the latest Assist firmware I find that I need to decrease the expo by about 5% (not to 5%) and I usually increase the rate by about 5%. This give me a plane that flies very close to the same with the gyro on or off. With the Assist (with latest firmware) I'd simply start with the rates and expo that the plane flew well with before the Assist was installed, assuming you are adding the Assist to an existing airplane that was well setup previously. It will probably feel a little dead when the Assist is enabled but it shouldn't be terrible. Then simply make some tweaks based on how it felt in flight.
NOTE: This is for the latest firmware ONLY as the original firmware required a big decrease in expo and a significant increase in rates to fly the same with Assist enabled vs Assist off but the latest firmware doesn't. Following the upgrade I would start with Assist off settings for rate/expo and get rid of the old Assist rates/expo as the plane may fell VERY sensitive following the upgrade.
Thanks a lot to all of you. You have been very helpful. I´m going to set up two old models and one new model with gyros. The first old one is a Philip Avonds F-15 that is very stable as it is and now it´s going to be equipped with a Jeti Assist receiver, V 1.10. The second old kite is an Xcalibur Plus which will be equipped with a Powerbox Mercury, also very stable as it is. The new one is a Ziroli Turbinator which is also going to be equipped with a Powerbox Mercury. I´ll take advantage of your advice in the process.
Jannica
Sweden
Jannica
Sweden
