Carf rebel pro
sewbusy (06-05-2023)
#703
Hello.. what is the length of the front section of the fuselage from the Rebel Pro (without the removable tail) ? Just to make sure it will fit the way I want in my car 😄
#705
Originally Posted by dccatl;[url=tel:12775684
12775684[/url]]82", I transport mine in my Kia Sorento with the seats folded down, nose hangs over the console about 8".
#707
Just curious. Does anyone feel that the 60 degree of flap on the Rebel seems a bit much? I was thinking of decreasing it a bit. It almost feels like the Rebel slows down a bit too much and requires a decent amount of power to continue flying without wing rocking. Also, does anyone know what the 60 degrees equals to in mm? Just curious.
thanks,
Tone
thanks,
Tone
#708
I Have mine at 55 degrees and lands slowly enough. Don't know the mm only degrees.
#709
Tone, I also have mine at 55 degrees. I do not know the measurement in mm. Like you, I also have to use a little throttle to keep it steady as the wing will rock a little (in windy conditions). I have also turned down the PowerBox SR2 gyro to 20% (as Andy {Barracuda} had indicated earlier in the thread), and the Pro is very steady throughout the F3S sequence. I practiced in a gusty 12-17 mph slightly crosswind and she was easy to control the wind correction. The landings are pretty slow with 55 degrees of flaps.
Wayne
Wayne
Skunkwrks (06-19-2023)
#710
Wayne
Wayne
Tone
sewbusy (06-20-2023)
#712
I'm on the home stretch, getting the Pro ready for maiden. For those that use the Electron. GS-200, what kind of settings do you use for the braking? Do you use the pulse ratio (ABS), what kind of limit for max braking does the Pro require?
Thanks for the input,
Peter
Peter
#713
Wayne
#714
Wayne, I have to agree with you that ER50 when full brakes are applied on asphalt it can stop in a short distance for a 44lb jet.
Mine is set the same 1/3 abs setting to prevent flat spotting tires an is very straight.
Hope this help Peter
Russell
Russell
#715
Thanks guys for the 1/3 tip. Ya, when I switched to my PB Core and put my Boomerang Sprint on it, I forgot to calibrate the Jet tronics air braking system box to the new radio. First flight I put a terrible flat spot on the Behotec tires and the wings shook senselessly for the rest of the day. 50 bucks later for 2 new tires, I'm trying not to make the same mistake twice.
#716
sewbusy (06-21-2023)
#720
Ailerons: 1¼ inches.
Flaps: 1 inch
Elevators: 1¼ inches
Rudder: 1½ inches.
As it is, I could go in one hole on my elevators and make it a 1 inch arm and still have enough throw for sequence flying, making the torque a little more. At present I have 753 oz/in on the surfaces, so I'm comfortable with the arms that I'm using.
Wayne
MarceloSabat (06-25-2023)
#721
I'm also running MKS HV9930.. using the new brass hub carbon arm MKS has they work very well.
Like Wayne has posted, these are the arm lengths
On the Rudder and elevator I slipped a carbon fibre rod over the 3mm thread rod with hysol to prevent and deflection under load.
Russell
Russell
The following 4 users liked this post by Racer686:
#723
Batteries
Hi,
How many batteries and what size would you recommend with this setup?
Jeti Cb 220 - All MKS HV servos
Electron retracts
Swiwin 220 turbine
nav lights from Unilights.
thought about using 2 jeti li-ion 2600mah for servos.. is this enough?
5 battery packs seems a lot for this plane.. 2 for rx, 1 for retracts, 1 for lights and 1 for turbine?
Electron retracts
Swiwin 220 turbine
#724
I use four batteries in total, two 4000mah Lipo for the CB power, one 3800mah for the ECU and smoke pump, one 2100 for the Electron gear
If the light is 11v, then you split the ECU power but increase the battery to 5000mah or run a 2100mah for 7.4 volt for the lights.
Are you using the Unilight system?
#725
Cool.. im afraid of using the same ECU battery, as it is also providing power for the engine's fuel pump.
Yes, its the Unilight system.. I bought the Pro combo for the rebel pro directly from Unilight.
thinking of using 2 batteries for cb and retracts, 1 for the turbine and 1 small for the lights
