Reload this Page >
CARF F-100 Lightweight Build
Old 04-04-2021, 07:17 AM
  #51
Desert Fox 1
Cheers!
Desert Fox 1
The following 2 users liked this post by Desert Fox 1:
Dansy (04-04-2021), Skunkwrks (04-04-2021)
Old 04-04-2021, 08:47 AM
  #52
Skunkwrks
Skunkwrks's Avatar
Great video and nice landing, it flys very well
Old 06-20-2021, 10:06 AM
  #53
Desert Fox 1
Cheers!
Desert Fox 1
Old 07-04-2021, 07:14 PM
  #54
Gary Jefferson
My Feedback: (167)
Default Speed Brake pics
Here are a few pics from my build on the F100. These might help someone when doing their own build.
Gary
My speed brake was not installed so I had to figure out how it should be attached. I simply used two short pieces of 4 mm rod glued to the bottom of the fuselage.
I added two additional supports on top of each 4 mm rod to hold them snug against the fuse. All radio gear sitting on ply plates directly on the bottom of the fuselage. The carbon fiber pieces glued to the speed brake are drilled out to 4mm to match the 4 mm pins. I also added 2” carbon fiber around the edges of the speed brake opening. This opening is a little weak in my opinion once the speed brake is cutout.
Fuel pump and JMP UAT location. Carbon fiber was added on each side of the front door opening as well.
Engine mount location will be at the front of the engine mounts for my K210.
Old 07-05-2021, 10:40 AM
  #55
Gary Jefferson
My Feedback: (167)
Default Tailpipe mounting
Turbine centered in tailpipe.
It is necessary to add ply extension pieces to the back of the carbon former to support the tailpipe at the back of the fuselage. These are not included so you will need to make your own ply extensions. Supporting the pipe at four locations is sufficient because the outer pipe is very rigid.
Old 07-05-2021, 10:52 AM
  #56
Gary Jefferson
My Feedback: (167)
Default Fuel System & Tailpipe
Plumbing for fuel system
Final position for turbine. It is a little further back than estimated to get proper distance from tail cone to pipe.
Rear of tailcone is in line with the carbon fiber bell mouth. Seems to be about 25mm from pipe.
skymaster68 (07-05-2021)
Old 07-05-2021, 06:07 PM
  #57
Gary Jefferson
My Feedback: (167)
Default Tailcone brackets
Tail brackets glued on tail cone.
Holes drilled in each bracket to attach to the rear carbon former.
Two coats of BVM heat shield on tail cone and it is ready to install.
Old 07-05-2021, 10:23 PM
  #58
IFLYBVM2
My Feedback: (360)
Nice work Gary !
Old 08-29-2021, 02:14 AM
  #59
jagerfrankyboy
Default Drop Tanks
Hello F100 friends - I have just ordered an F 100 in the Thunderbirds Scheme and I am still thinking about whether I should also order the Drop Tanks - does anyone have any experience with it? I think it's 600g more weight. But most of them fly without drop tanks - why? can someone tell me his experiences.
Many thanks from Munich Germany.
Regards Frank
Old 08-29-2021, 07:53 AM
  #60
skymaster68
Regards Frank
Hallo !!!
I have an F100 on the same Thunderbirds scheme, I'm close to finish the build, I didn't order the drop tanks as for my knowledge the TB did not fly at the shows with them installed, just for cross country flights were more enduranse was needed, that's the only reason I didn't order them... I'll be always doing the Solo Flight hahaha !!
Any way, does any one know what is the proper CG?
Also, anyone has an aperating canopy? if so how did you make it open and what's requiere to do so???....
Old 08-29-2021, 11:12 AM
  #61
jagerfrankyboy
Default back to the question Drop Tank
Regards Frank
can we go ahead with the question about experiences Drop Tank - Thx Fank
Old 06-09-2022, 08:57 PM
  #62
Jet-Bob
Finishing the build on my CARF Hun… your RCU pics have been very helpful. Since the model comes with no instructions (it’s an easy build), I am seeking guidance on throws and the CG (location,UAT full?, gear down?) Thanks.
Old 09-27-2022, 09:40 PM
  #63
wojtek
My Feedback: (73)
wojtek's Avatar
wow, what a great thread. I'm about to pull the trigger on an order for one of these bad boys, and cant wait to get started! it looks like a super quick and easy build too! It will be 5+ months to get the order processed ( also getting a DG 800 going on order at the same time ) so hopefully i can wrap up some other projects in the shop before then!!
I believe I'm good to go on most details and info, however I have not seen any info on how the few guys who use drag chutes have them set up. since CARF will be doing a good amount of the paint/finish on the order, I'm wondering if there is anything I can look for them to do before paint/finish to help facilitate for a chute ... ??? on the full scale, i believe the chute pops out from a dual door compartment under the tail and that would be super simple for me to cut out, box and hinge, but then the chord attachment point is under the rudder and the line i think would need to tuck up and around the cone somehow ... that's the part where I'm not sure what others have done and what is realistically possible .... any suggestions ?
also, is anyone aware of any scale accessories for the gear and/or inside the doors ? .. If not, I may end up CADing some bits up once I get the plane in
also @MattyMatt , I love the scheme and execution on it! beautiful jet !!
Old 10-18-2022, 09:28 AM
  #64
JustJets
My Feedback: (15)
Default Comp ARF F100
Taylor Made Products and paints used throughout
Rub on’s still need to be applied and some more weathering top engine bay and rudder deck.
Lots of possibilities with this updated kit. Core Radio, Powerbox Competition Pro controller, JetCat P250 Pro, paints, Paint mask and Hot Section kit from Tailored Made.
Rub On markings Tailored Made to be added.
Old 10-20-2022, 05:46 AM
  #65
SkyKnight
My Feedback: (67)
SkyKnight's Avatar
Such a masterpiece!
Old 04-09-2023, 05:57 AM
  #66
JP-1
One of the U.K. JMA members flying his CARF F100D at the weekend
Alistair Powers
Old 03-31-2024, 12:56 AM
  #67
Merlino
Wow, great pictures, great aircraft. Could somebody tell my the dry weight?
best regards
Oliver
