1/4" pin for Prolink retract.
NJ
You can get a1/4 rod cut the length and put a groove around the top and put a c clip on it. It also easer to replace and or in an emergency a door hinge pin works if your easy on the landings.
patf (02-14-2022)
grbaker (02-13-2022)
My Feedback: (7)
Guys, your pin's ideas are fantastic and I will be trying them soon, I ordered two 1/4 " and two 6mm pins for my Reaction 54 nose retract, on that one the pin came too short and also needs replacement, John has offered me two 1/4" pins that he has, I'm taking them also and appreciate his generosity very much.
I will post my results here.
Thank you
Thank you
My Feedback: (7)
Guys
I got the pins from John ( thank you for your generosity and kindness ) they actually came a few days ago, I finally got home from work to find all kind of goodies on my garage table, it feels like early X-mas 😀
I also got me two 1/4" and two 6mm release pins from McMaster-Carr to experiment with them, I'm also curious to see how the Cap screw will work, I will get a pair from HD to experiment.
grbaker (02-27-2022)
