Reload this Page >
Byron f15 oweners
Byron f15 oweners
Old 05-23-2004, 05:48 PM
Jetjockgb
Jetjockgb's Avatar
Default Byron f15 oweners
Hi All,
I'am in the process of getting the Byron F15 kit ,but dose not have any plans.Do you know any where I could get some,I need them for c of g and through's.
Also has anyone got any mod's for the 15 [CONVERSIONS FOR TWIN OR SINGLE TURBINE].
I would like to get a set of true scale legs and wheel's for the f15
Any ideas or thought's.would be welcome.
Cheers Graham
Last edited by BarracudaHockey; 04-19-2018 at 06:15 AM. Reason: remove inappropriate link
Old 05-23-2004, 06:03 PM
P. Richards
P. Richards's Avatar
Default RE: BYRON F15 OWENERS
Glennis and a few others made scale gear for the Mach 2 F-15 which is about the same size as the Byron. Check them out, as far as C of G don't know that one...
P. Richards aka SWAT TEAM
Old 05-23-2004, 09:27 PM
jroth
My Feedback: (60)
jroth's Avatar
Hi,
I have all of the original paperwork, I will have to find them and email to you, I flew mine on 2 OS 91s. I have the turbine and pipe to convert, but I am working on other projects first.
I also have information and photos from someone in California or Florida who converted to a single 30# turbine with a bifracuated pipe.
I will try to send info from my office on Monday.
John
Old 05-24-2004, 07:59 AM
Hinckley Bill
My Feedback: (569)
Hey John,
I just picked up a gorgeous Byron's F15 from Ron in Ohio......he's installed two OS 91 DF's for power and I'll likely go with this for the time being. I also got the instructions for the kit but no plans....did they come with the original kit and do you have them (if yes could I get a set)?
Would it be possible to get a copy of the information and photos for the conversion to a single 30# turbine with Bifracuated pipe....this would be the ulitmate combination.
Thanks so much...
Bill
Old 05-24-2004, 08:42 AM
GlennisAircraft
We may not list the wheels on our website, but if you need the info, e-mail us and we can check the status of them
Can do the scale legs also -
Dennis Rastetter
Glennis Aircraft
Old 05-24-2004, 06:44 PM
Jetjockgb
Jetjockgb's Avatar
Default RE: BYRON F15 OWENERS [BIG ASS BIRD]
Hi all,
Thanks for all the info on the F15 guy's, just need to get the c-g and the through's.
Anyone know who dose a thrust tube for it.
Cheers Graham.
WWW.TIGERMODELS.NET
Old 05-25-2004, 07:07 AM
mick15
mick15's Avatar
Is that Graham Bu******
I think I have all the info you require I'm converting one also. The CG is 39" forward of the jet outlet
M
Old 05-25-2004, 08:05 AM
Jetjockgb
Jetjockgb's Avatar
Hi Mick,
Mick how do you fancy converting the F15 Into a Strike Eagle. Thats what I'm going to do with mine.
I will make a plug for the canopy.Hear is some pics of the Yellow F18 which I have made into a { B version}.
Hope you feel better soon.
Cheers Graham.
WWW.TIGERMODELS.NET
ID:	136195   Click image for larger version
Old 05-27-2004, 08:28 AM
FireBee
My Feedback: (34)
Guys, I completely refurbished mine from one I bought on RCU. Call John Craig (304) 232-7511 as Iron Bay now has the old Byron line. He has all the parts and a new fuel regulator that will provide exact amount of fuel to your fans even when tanks are far away.
See also www.Ironbaymodels.com
The instruction book said throws work out to 1"
I copy:
"Elev (measured at root trailing edge) = 1"
Aileron travel 1" up 1" down
Rudder 1 " left/right
Measure the CG location down the middle of the fuselage at the tail pipe opening. a distance of 38 inches ahead of the end of the tailpipe is the average CG location."
I use 38 inches and used a trapeze method to balance upright w/ fuel loaded and gear up. Trapeze lets you see difference when you lower the gear. (CG comes out 5 inches from the back edge of the airbrake as another "rough" reference.)
I have slightly more aileron throw for faster rolls.
I use -24 expo on elev and ailerons for Futaba. Plane flies great single engine as I had 3 during initial test flights.
Also get the new wheels. They are harder rubber and will not roll of the rims. Happened to my test pilot on the 1st flight. I also filled nosewheel with rubber inserts (car R/C part).
John, where did you get turbine conversion kit from? I want to upgrade in a few years.
Mike sends
Old 05-28-2004, 08:35 PM
jrocket
Matrix Machine Tool makes a set that will fit the Byron F15. Its not advertised on the web site though.
http://home.earthlink.net/~matrixmt/
ORIGINAL: Jetjockgb
Hi All,
Cheers Graham
WWW.TIGERMODELS.NET
ID:	137368   Click image for larger version
Old 04-20-2011, 04:11 PM
vfrank59
Tam of Tamjets sells the Byron bifurcated pipe. I bought mine from him. I have the original prototype byron f-15 with Rossi 81's. Still flys great. Also have a unbuilt kit i was going to convert to a Jetcat p120 turbine.
Vern
Old 04-28-2011, 01:37 AM
AlexKuys
Hi John
WEare also in proces of coverting one to turbine, could you please e mail info to me as well, thanks.
Alex
Old 04-28-2011, 02:24 AM
cmjets
cmjets's Avatar
Hello:
I have one friend that has one, but unflown. 2 Jetcat 80.
https://picasaweb.google.com/cmjets2...07044684468962
The Lg are in resin (fan version) and he need change.
Regards form Spain.
Carlos Márquez.
___________________________
http://cmjets.blogspot.com/
Old 04-28-2011, 03:03 AM
skyhawknut
Why is everyone trying to get info from a 7 year old thread?
Old 04-28-2011, 04:51 AM
budjet
hi graham
think i recognise the f18 is that the fus you got off me about ten years ago!!!!!!!!!!!!!
cheers mick s (north weald)
Old 04-18-2018, 08:23 AM
PineBaron
My Feedback: (38)
Not attempting to revive an old thread but I have a completely assembled Byron F15 Eagle never flown, painted, servos installed, brand new OS engines (never run) original box, manuals etc. Just never got around to locating a tarmac runway hence never flown. Even have a a carbon fiber tube for wings which is the only thing I did not install yet. I'm in WA.
Old 04-18-2018, 09:52 AM
vernonms
Call me if you are interested in selling. Vernon 601-955-3826
Old 04-18-2018, 01:44 PM
foodstick
foodstick's Avatar
I have a lot of fond memories watching Carl Spurlock fly this model.. Of all the Byron stuff he flew.. this and the SR71 were the best...
Old 04-19-2018, 06:12 AM
A7Bldr
My Feedback: (40)
Are you sure you don't mean Cloud Dancers?
Old 09-07-2018, 06:51 PM
PineBaron
My Feedback: (38)
For sale ready to fly.
Old 05-03-2020, 04:53 AM
PineBaron
My Feedback: (38)
Still waiting for you to pick it up
Old 05-03-2020, 05:37 AM
P. Richards
Wow this old thread brought back memories.
P. Richards aka SwatTeam
Old 12-06-2020, 07:49 AM
PineBaron
My Feedback: (38)
The Byron F15 is still available for sale/pickup in Blaine WA 98230
Contact me if interested.
Old 12-06-2020, 02:17 PM
vernonms
I would love the F15 but the amount of money it would cost to get it wouldn’t work. Google says ur 2500 miles from me, one way. Thanks for checking.
vernon
Old 02-05-2021, 07:23 AM
Newboy111
Default byron f15
Cheers Graham[/QUOTE]
