Removing Flitemetal covering
I recently bought a BVM T 33 from E bay at what I thought was a bargain price. It turned out to be in need of a full strip down and re paint. It is however covered in what I think is flitemetal covering or some other aluminium self adhesive tape. Trying to peel it off results in a top thin transparent layer peeling off with a now sticky aluminium remaining on the model.
I would really appreciate it if someone can tell me the easiest way to remove this covering.
kkn
kkn
My Feedback: (48)
RE: Removing Flitemetal covering
What you have doesnt sound like Flite Metal. There is no top thin clear layer over Flite Metal. Flite Metal is very hard to pull up, but will. Ive pulled up some before and it will come off but will sometimes leave a glue behind that goo remover will take off. If it wont pull up I would try to either sand it or recover it.
Scott
Scott
Thanks Guys,
I have tried heating it quickly with a blow lamp, but it just burns off the plastic top layer. Will try it with a hair dryer and goo remover. I cannot cover on top of it as there is some damage I need to repair in some areas.
Thanks again, will let you know how it goes.
regards
kkn
regards
kkn
My Feedback: (12)
I think what you have is presto. I have use alot of it. When I remove it on a older plane it comes off the way you stated it. Just use a good lacker thinner. Some thing that has some kick to remove the silver and glue. You will be useing alot of paper towels. Dan Avilla
3M General Purpose Adhesive Cleaner, pt# 8984...works great, will not harm plastic, paint or gelcoat. Soak a rag or towel and place on surface...let it sit for a bit, 5 mins or so and the stuck stuff should lift right off.
Jeff
Jeff
Thanks again everybody, will try the 3M or thinner solution as it seems much easier than heating. Will let you guys know. Thanks again
kkn
kkn
Hi,
I have tried the 3 M cleaner, and it works, but the top layer must still be peeled off. It is painstaking but works. Thanks for the advice everybody.
kkn
kkn
Sounds like you do have a Presto covered plane. Its a termo-set plastic product, not aluminum. You can remove
its adhesive residue with Goo Gone lemon oil based solvent. The Presto clear is what prevents it from conforming
easily to the compound curves of a model. Flite-Metal has a "stretch" factor of up to 25% of area mass and doesn't
have retentive problems on compound curves. After using Goo Gone to remove residue, wipe entire surface down
with denatured alcohol to remove Goo Gone's oil residue.
layer peeling off with a now sticky aluminium remaining on the model. I would really appreciate it if someone
can tell me the easiest way to remove this covering. Thanks kkn
real aluminum with an adhesive layer directly "beneath the aluminum" between a silicone release sheet and
the aluminum. There is no transparent covering over the aluminum, nor is there anything sticky other than
the adhesive prior to its curing.
This material sounds like a metalized Mylar similar to that available in 5" wide strips. There are more than
one brand of Mylar and vinyl adhesive backed graphic "trim sheets". Some of these have a metalized back
coated adhesive coating on a clear plastic front layer. Removing these can be a problematic mess.
Removing is easily achieved with a hot air gun blowing onto the panel you desire to
remove. It is more often than not release all the adhesive with the aluminum if you are patient and evenly
distribute the heat.
Good luck removing and repairing what ever it is your BVM T-33 is covered with.
Hi Kelly,
Typically a clear coat can not be pulled away from as a layer. This sounds like Presto.
When removed, after a Prep-Sol wipe down there is no sticky residue or the aluminum coming up.
There are a number of people who think is a plastic laminate like Presto. After years
of defining the product they persist.
