JetLegend F-16 (1/8) Testflight
#152
RE: JetLegend F-16 (1/8) Testflight
Hello
I just want to share my new JL F-16 with you.
Lasse your construction is great any more recommendations will be great I also want to install the lights.
Assaf
Assaf
#153
My Feedback: (10)
CT
Hi Assaf,
Great looking F-16. What are you planning on powering it with? Is there anyway you could take some upclose photos the the main gear door cylinders? I need to rework mine as they dont open quite far enough for the wheels to clear when they are retracted.
Rich
Rich
#154
ORIGINAL: xurifle06
Hi Assaf,
Rich
Hi Assaf,
Rich
Assaf
#155
Hello Assaf,
Is there anyway you could take measure the main gear door cylinders and the noise wheel door cylinder too ? I now working on my F16 too ..
Alex
Alex
#156
Hi, i'm mounting a mine f 16 from jetlegend. First all thank you for your photo, are a must for mount this plane.
So i have a P70 to install there, can you explain if the 2 tank plus a uat is enought for 10 minutes of flight?
I have some doubt about the mini servo in the wings.
Thank you
Thank you
#161
My Feedback: (67)
Check out my new ordnance. I am going to put a new P70 on it for all these extra weight.
Has anyone put a P80 on this bird yet? I tried P60 and P70 so far. Got a spare P80, and my builder said that it fits in the bay, but need to shorten the pipe.
Mike
www.globaljetclub.com
Mike
#163
My Feedback: (57)
ORIGINAL: mikedenilin
Mike
Mike
#164
Hi Mike, about 7 minutes with P70 with 2,5 litres( more or less the two main tank) it's strange beacause in my harpoon with simjet 3000 i have 2,5 litres and i make a 10 minutes of flight.
#165
Mike
Mike
Do you sell the ordinance for the F-16? is it painted? what colors? and how much does it cost.
Thanks. Regards
#166
My Feedback: (67)
Yup, F16 is not a Falcon without these missiles.
These are the color of the missiles that I have.
And the cockpit kit for JL F-16 1/8, just drop right in. I still need to figure out where I can get the 1/8 pilot figure.
Mike
Mike
#171
Yes, also i interested to a centerline tank, but if there is a possibility to install a fuel tank or smoke tank, like the old centerline tank of bvm.
#173
My Feedback: (57)
Guys, on my Tamjets F-16 wich is exactly the same size I have two 12 oz Sullivan tanks mounted on top of the inlet. I'm planning on doing the same here. The tanks are good for about 45 seconds of smoke, enough for a realistic smoke on/smoke off sequence. Why don't you guys use a similar setup?
I'm afraid that a centerline tank will only add to the already high drag upon landing.
David
David
#175
Hi Assaf,
Love the scheme - bought paint this week to redo my original JL F16 AND my Avonds F15 both in IAF colours.
How did you do the black lines?
David
David
