Reload this Page >
JetLegend F-16 (1/8) Testflight
Old 10-27-2008, 06:25 PM
  #151
Lasse Palm
Lasse Palm's Avatar
Default RE: JetLegend F-16 (1/8) Testflight
More pics !
Lasse P
ID:	1060183   Click image for larger version
ID:	1060184   Click image for larger version
ID:	1060185   Click image for larger version
ID:	1060186   Click image for larger version
ID:	1060187   Click image for larger version
Old 10-28-2008, 11:16 AM
  #152
cool3d
cool3d's Avatar
Hello
I just want to share my new JL F-16 with you.
Lasse your construction is great any more recommendations will be great I also want to install the lights.
Assaf
ID:	1060643   Click image for larger version
ID:	1060644   Click image for larger version
ID:	1060645   Click image for larger version
ID:	1060646   Click image for larger version
ID:	1060647   Click image for larger version
Old 10-28-2008, 11:33 AM
  #153
xurifle06
My Feedback: (10)
Hi Assaf,
Great looking F-16. What are you planning on powering it with? Is there anyway you could take some upclose photos the the main gear door cylinders? I need to rework mine as they dont open quite far enough for the wheels to clear when they are retracted.
Rich
Old 10-28-2008, 11:54 AM
  #154
cool3d
cool3d's Avatar
ORIGINAL: xurifle06
Hi Assaf,
Rich
Thank you Rich I am planning to put Jet cat P-70 Check the pictures !
Assaf
ID:	1060668   Click image for larger version
ID:	1060669   Click image for larger version
ID:	1060670   Click image for larger version
ID:	1060671   Click image for larger version
Old 11-03-2008, 11:44 PM
  #155
Alex wong
Hello Assaf,
Is there anyway you could take measure the main gear door cylinders and the noise wheel door cylinder too ? I now working on my F16 too ..
Alex
Old 12-01-2008, 06:43 AM
  #156
MAXIAN
Hi, i'm mounting a mine f 16 from jetlegend. First all thank you for your photo, are a must for mount this plane.
So i have a P70 to install there, can you explain if the 2 tank plus a uat is enought for 10 minutes of flight?
I have some doubt about the mini servo in the wings.
Thank you
Old 12-01-2008, 04:12 PM
  #157
mikedenilin
My Feedback: (67)
Hi Maxian,
No, won't go more than 7 minutes with a P70, you need to add one center tank.
Mike
Old 12-01-2008, 05:20 PM
  #158
sweetpea01
My Feedback: (10)
Mike- Still haven't started on mine yet, but soon......real soon
Old 12-01-2008, 05:32 PM
  #159
mikedenilin
My Feedback: (67)
Not Yet? Hurry up, it's cold up there, you are running out of flying time. Mike
Old 12-01-2008, 05:47 PM
  #160
sweetpea01
My Feedback: (10)
I'm trying to finish up my P-47 first......its real close now. Just need a couple of good paint days. The 16 is next on the block
Old 12-01-2008, 07:48 PM
  #161
mikedenilin
My Feedback: (67)
Check out my new ordnance. I am going to put a new P70 on it for all these extra weight.
Has anyone put a P80 on this bird yet? I tried P60 and P70 so far. Got a spare P80, and my builder said that it fits in the bay, but need to shorten the pipe.
Mike
www.globaljetclub.com
Old 12-01-2008, 08:32 PM
  #162
sweetpea01
My Feedback: (10)
I like it........I'm going to do the centerline (smoketank). Maybe I'll do all the extra stuff as well, but I'd have to make the wing tanks drop.......don't want to limit my G's like the real one....LOL
Old 12-02-2008, 12:17 AM
  #163
FalconWings
My Feedback: (57)
FalconWings's Avatar
ORIGINAL: mikedenilin
Mike
Yeah baby......ordinance is the way to do it!
Old 12-02-2008, 02:31 AM
  #164
MAXIAN
Hi Mike, about 7 minutes with P70 with 2,5 litres( more or less the two main tank) it's strange beacause in my harpoon with simjet 3000 i have 2,5 litres and i make a 10 minutes of flight.
Old 12-02-2008, 04:25 AM
  #165
extra 300
Mike
Mike,
Do you sell the ordinance for the F-16? is it painted? what colors? and how much does it cost.
Thanks. Regards
Old 12-02-2008, 05:23 AM
  #166
mikedenilin
My Feedback: (67)
Yup, F16 is not a Falcon without these missiles.
These are the color of the missiles that I have.
And the cockpit kit for JL F-16 1/8, just drop right in. I still need to figure out where I can get the 1/8 pilot figure.
Mike
ID:	1082580   Click image for larger version
ID:	1082581   Click image for larger version
ID:	1082582   Click image for larger version
ID:	1082583   Click image for larger version
ID:	1082584   Click image for larger version
ID:	1082585   Click image for larger version
ID:	1082586   Click image for larger version
Old 12-02-2008, 05:34 AM
  #167
MAXIAN
Mike, but a centerline tank with smoke tank inside or a supplementary tank?
Bye from Massimo
Old 12-02-2008, 05:50 AM
  #168
mikedenilin
My Feedback: (67)
Massimo,
I'm working on that for my 1/6 scale F16.
If there are enough interest for a 1/8 scale F16 centerline smoke tank. I will work on that. I will need to give some carrots and sticks to my builder.
Mike
Old 12-02-2008, 05:54 AM
  #169
extra 300
Mike,
Definitely intersted for smoke tank too.
Sent you a PM for ordinance and cockpit.
please advise
Regards.
Old 12-02-2008, 09:30 AM
  #170
FalconWings
My Feedback: (57)
FYI, Ralle at Taylormade Decals has the decals and markings for all of the ordinance.
Old 12-02-2008, 01:00 PM
  #171
MAXIAN
Yes, also i interested to a centerline tank, but if there is a possibility to install a fuel tank or smoke tank, like the old centerline tank of bvm.
Old 12-02-2008, 03:29 PM
  #172
sweetpea01
My Feedback: (10)
Mike you know I'd take a 1/8th centerline smoke tank. Been looking at the one from Dreamworks but it isn't in stock and is very pricey and I've yet to measure if it will fit the JL
Old 12-02-2008, 04:50 PM
  #173
FalconWings
My Feedback: (57)
Guys, on my Tamjets F-16 wich is exactly the same size I have two 12 oz Sullivan tanks mounted on top of the inlet. I'm planning on doing the same here. The tanks are good for about 45 seconds of smoke, enough for a realistic smoke on/smoke off sequence. Why don't you guys use a similar setup?
I'm afraid that a centerline tank will only add to the already high drag upon landing.
David
Old 12-02-2008, 05:10 PM
  #174
sweetpea01
My Feedback: (10)
Because its more scale. That is my only reason for putting the smoke there instead. Technically you could put it in the wing tanks but that invites all sorts of extra connections and balance issues if it drains unequal.
Old 06-27-2009, 09:22 AM
  #175
hymie42
Hi Assaf,
Love the scheme - bought paint this week to redo my original JL F16 AND my Avonds F15 both in IAF colours.
How did you do the black lines?
David
