Reload this Page >
120" c-5 galaxy project started
Old 05-23-2010, 04:33 PM
  #251
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
Default RE: 120
hinging mech for visor? AWESOME!! Lemme see it when you sketch it up!!
Old 05-23-2010, 08:42 PM
  #252
invertmast
My Feedback: (23)
invertmast's Avatar
Default RE: 120
hey nick... Can you post up a few pictures of FRED with the visor up with it zoomed in near the hinge setup.. if its how i think it is, my idea will be pretty close to exactly how the fullscale is and make life fairly simple.
Old 05-24-2010, 12:44 AM
  #253
Props4ever
Default RE: 120
Hey Nick,
Bit of inspiration for ya bud....
[youtube]http://www.youtube.com/watch?v=zhuqoUrrmns&feature=related[/youtube]
Lets ya see how sweet ur C5 will once airborn....
Sam
Old 05-24-2010, 06:02 AM
  #254
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
Default RE: 120
Sam, i have seen that one before!! Good stuff, i actually started building a mini version of mine in depron ,that had a 50 inch ws....never finished it[:@]
Thomas, will do! I will say that the hinging isnt really the hard part, it is tha actuation of it!! Will take pictures sometime during this trip...
Here's one from Airliners.net to show ya whats up......There is a hydraulic motor in the center under the flightdeck that spins a chain and gear assembly that grab the track connected to the visor[X(]
Old 05-24-2010, 11:50 AM
  #255
Props4ever
Default RE: 120
Nick,
Can't you get any drawings of this section from maintenance manuals, that will show exactly whats involved hinging and actuation process for the visor. Like you say
There is a hydraulic motor in the center under the flightdeck that spins a chain and gear assembly that grab the track connected to the visor.
So if you can find drawings we can then work from there and come up with a system for functioning visor, i'm sure between 3 of us we can make it happen for ya bud
As far as baby C5 goes, i think you should do it and use it for CG calculations and as proof of concept as far as models are concerned. I made small 1/67th scale chuck glider Concorde for this very purpose and it flies max of 100ft!! by hand launching it. Bob is doing same for his big B1 Bomber, it's worth it bro.....
Positing pics of inflight baby Concorde glider, after flights on top of CG machine and then CG machines itself.
Sam
ID:	1441753   Click image for larger version
ID:	1441754   Click image for larger version
ID:	1441755   Click image for larger version
Old 05-24-2010, 03:44 PM
  #256
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
Default RE: 120
Sam, the chuck glider is a great idea, was planning on using it as one of my cg-calculations when prepping it for flight (whenever that may be)[:@] A friend in AZ that made a scratchbuilt a-7 used that idea i believe too! I was also going to use our actual weight/balance books for the real airplane, just scaled down of course, because the wing and airfoils are all scale to the actual jet, so they will be able to provide some type of insight and guidance[X(]. I cant wait to get home and start messing with these wings now, pretty exciting!!
Old 05-27-2010, 10:02 PM
  #257
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
Default RE: 120
Sam and Thomas, i had a chance to snap some shot of the visor up and the mechanics under the flight deck and the hinge point. If you notice, the visor skin back at the hinge area folds outside of the slot...
ID:	1443634   Click image for larger version
ID:	1443635   Click image for larger version
ID:	1443636   Click image for larger version
ID:	1443637   Click image for larger version
Old 06-09-2010, 07:09 PM
  #258
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
Default RE: 120
Got my plans drawn up for the v-stab and all my ribs drawn (literally drawn on graph paper!!) They are all cut, just need to cut slots for the CF laminated spruce stringers and the holes for the 1/2 inch carbon rods that will be clamped in at the fuse. Heres some pics from today
ID:	1450887   Click image for larger version
ID:	1450888   Click image for larger version
ID:	1450889   Click image for larger version
ID:	1450890   Click image for larger version
Old 06-11-2010, 05:49 PM
  #259
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
Default RE: 120
update: Have the whole left side just about ready for sheeting! I think it looks good and strong, still need to find another of the CF round spars that i have. They are 1/2 inch and have a thin wall design so they are liiiigghhht but strong........will look around. Also am going to beef up the main spar carrying ribs with 1/16th ply for a lil more strength...The pictures dont show it but i have already installed the hinge boxes. Also got my dual Rudder servo mounting pads installed. They are situated so that the servo center is directly centered and it will be a pull-pull setup. All linkages will be internal for a nice clean exterior. Anyways, heres some pix
ID:	1451603   Click image for larger version
ID:	1451604   Click image for larger version
ID:	1451605   Click image for larger version
Old 06-11-2010, 07:12 PM
  #260
invertmast
My Feedback: (23)
invertmast's Avatar
Default RE: 120
looks good nick. Have you thought of laying a bit of carbon tow onto the main spars? It would add a bit of rigidity, but i guess your carbon tubes are doing the same thing...
Old 01-08-2011, 06:36 PM
  #261
Chrisl1471
Default RE: 120
LOL Been reading your guys' post and AHHHH interservice rivialies I LOVE EM.....from and Air Force Brat, Army Soldier (rotor wing mech), and Brother to a Jarhead.  And to you C-5 critics out there...better look up the C-5M !!!! I work at lockheed and am on the project and we are blowing away records everyday!  Cheers
Old 02-12-2011, 06:31 AM
  #262
drdoom
My Feedback: (9)
Default RE: 120
How do you keep the shop so clean? I need to burn mine and start over. Oh almost forgot, Back to work!!!! You Know. A little here a Little there.
Old 02-12-2011, 07:44 AM
  #263
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
Default RE: 120
Haha, i keep it clean because it is usually months in between work sessions [:@] It's B.S but the Air Force has me flying 70 out of 90 days recently (ever since i became an instructor)
Old 02-12-2011, 07:54 AM
  #264
Fleet
Default RE: 120
Thats alot of days stuck off station waiting for parts.
Ray W.
Old 02-12-2011, 08:26 AM
  #265
WhoDaMan
My Feedback: (164)
WhoDaMan's Avatar
Default RE: 120
CAUSE,,,,YOUDAMAN
ORIGINAL: NickC5FE
Old 02-12-2011, 08:39 AM
  #266
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
Default RE: 120
No doubt Ray!
Thanks Big D- I thought youdaman!!>>??
Old 02-12-2011, 09:10 AM
  #267
Fleet
Default RE: 120
Nick, if your ever get to KCHS with any ground time, give me a jingle. My hangar is just under the control tower.
Ray W.
5,000 hrs sitting sideways.
Old 02-12-2011, 10:12 AM
  #268
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
Default RE: 120
Hey Ray, i was just in Charleston (broke) for 2 days. i was on spot 29. Too bad man, would have gave you a ring! We left outta KCHS and we had an engine vibe, a left aft main gear that wouldnt retract and an unpress door open........Great day.....
Old 02-12-2011, 10:18 AM
  #269
Fleet
Default RE: 120
Were you able to get a glimpse of the new Boeing hangar from the pattern? They plan on building the 787 there once it gets in major production mode.
A young guy visited me the other day who was an enlisted mech here, worked with me on a project before he went to OTS. I think he is now C-5 at Travis. I wish I could remember his name.
We talked C-5s for a while. He was astounded that I worked on the first assigned series of C-5s here in the 70s. I'm glad I escaped the move to Dover when Mendal Rivers died.
Old 02-12-2011, 10:20 AM
  #270
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
Default RE: 120
Crazy! Yeah, i have seen the new hangar...it s massive! i have also had the opportunity to see the dreamlifter there from time to time....
Next time i am through there i will send you a PM. We stop through every third or so mission out....
Old 02-12-2011, 10:23 AM
  #271
Fleet
Default RE: 120
That would be a treat. Please do.
Ray W.
Old 08-05-2012, 09:00 PM
  #272
fordtech09
Default RE: 120
Hey Guys, just checking in and see how this forum is going. Finally found some one with a set of plans for the C-5 and i got a set beeing made up so hopefully i'll have them in a couple of days.
Here's a picture and the builder of the airplane.
Old 08-06-2012, 03:09 AM
  #273
Frank Sopwith
Frank Sopwith's Avatar
Default RE: 120
Impressive in flight too
cheers,
Frank
ID:	1789600   Click image for larger version
Old 08-08-2012, 11:19 PM
  #274
Props4ever
Default RE: 120
Beautiful model there Frank, i hope Nick is also plugging away on his project unless he is away on Military duties....
Old 08-13-2012, 07:53 PM
  #275
fordtech09
Default RE: 120
Hi Frank, nice shoots of the C-5.I like the paint scheme due to the fact i'm retired from the USAF. I was a Aircraft Mainteance Technican/ Dedicated Crew Chief and was stationed there at Travis when we got the first C-5B
models.I actually flew with 87-0038 during Desert Storm back in 91. Back then she was called the Galaxy Solano and she was in camo paint.
I have been in email contact with Grad and he sent me some of his drawings of the build. I'm in the process of converting them over to Standard measure so i can start building a C-5 also.
I'm going with the same motors but i would like more details on the set -up. I sent a email to Jepe concerning the availablity of the jet90-6s and if they could ship to the USA
I plan to start my construction in January so i got lots to do.
Jerry
